Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
track times
Old Aug 1, 2005 | 02:34 PM
04GTgirl's Avatar
04GTgirl
Default RE: track times
i appreciate the help. i'll try that the next time i go. i will have the slips in just 2 more hours!
Old Aug 1, 2005 | 02:55 PM
firemedix911's Avatar
firemedix911
Come off at idle....anything higher and you're gonna blow the tires off. Line up and slip the clutch until it grabs, then nail it.
98ls1 said it. Ride the clutch. What was your mph?
Old Aug 1, 2005 | 02:56 PM
jkm1987's Avatar
jkm1987
when i had my stock gears i could rev to about 2000-2300 and hook up fairly well any higher i would spin through first my 60ft were 2.2's now that i have 3.73's i can tell itll be a little harder to launch ill find out tommorow night but yea lower your tire pressure if you have stock 245/45/17's try lowering to 23 or 25 thats what i did and that helps heat them up by a quick burnout first and see what happens just ride the clutch til you can feel it hook then open her up thats what i do
Old Aug 1, 2005 | 03:06 PM
dc_mann8's Avatar
dc_mann8
well you could up the pressure in ur froint tires, and lower the rears to about 20 at lowest. do a small little burnout without going on the water just to clean the tires, i take off from around 2200 you will just have to try and see what works best for you.
Old Aug 1, 2005 | 03:54 PM
04GTgirl's Avatar
04GTgirl
ok, here is the first run and then the last one. the four in between were similar to the last run.
reaction: 1.117
60 feetL: 2.447
660 feet: 9.946
E.T. : 15.299
MPH: 92
reaction: .547
60 feet: 2.797
660 feet: 10.399
E.T. : 15.793
MPH: 92
Old Aug 1, 2005 | 03:58 PM
Dan04COBRA's Avatar
Dan04COBRA
This is with your 04GT? Manual too?
Your 60 foot times are horrible. How fast can you shift? Even spinning bad your MPH should be considerably better than that.
Practice practice practice. You should find a place to launch your car, start by leaving at idle and work your way up, leaving as quickly as possible with as little wheel spin as possible.
Old Aug 1, 2005 | 04:15 PM
04GTgirl's Avatar
04GTgirl
yes, this is the 04. and i have been driving these for about 11 years now, so, i would say that i don't shift too bad. and the car did this in first and second gear. it just felt weird because no matter how many times i ran the car, it did the same thing.
Old Aug 1, 2005 | 05:41 PM
TommyV8's Avatar
TommyV8
All-season street radials are pretty much useless for drag racing and will kill your ET, but like Dan said your MPH should be unaffected by that. In good weather I believe your car should trap high 90's, close to 100.
Old Aug 1, 2005 | 05:59 PM
firemedix911
Your car should be trapping 98-100 mph. My best mph trap was las week 101mph but i got a couple of mods more than you do. Keep working on it. My 1st time @ the track was also a disaster. Not as bad but not what I expected. Keep going and practicing.
Old Aug 1, 2005 | 07:08 PM
04GTgirl's Avatar
04GTgirl
thanks for all the info. i will eventually get the mods done that i want. i just wanted to get a basic idea of what my car would do. thanks to all you guys!
