Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
mph to get 13s??
Old Sep 5, 2005 | 10:38 PM
dc_mann8's Avatar
dc_mann8
Default mph to get 13s??
people say mph will tell what you run.. well i go about 94.5 mph, which normally wouldnt be a 13 second pass right? but i have 2.3 60 foots, on slicks, i should will 1.9's right??? which is .4 off the 60 foot, which is about .8 off the 1/4, so my 14.71 at 94.5 SHOULD be around 13.91 right???
Old Sep 5, 2005 | 10:58 PM
dan's Avatar
dan
Default RE: mph to get 13s??
im no professional but i think u need a higher trap speed to get into the 13's. and i think speeding up your 60 foot from a 2.3 to a 1.9 (which is .4 seconds faster) will yield a .4 second faster 1/4 so you will pass at 14.31.
Old Sep 5, 2005 | 11:00 PM
dan's Avatar
dan
accidentaly double posted
Old Sep 5, 2005 | 11:15 PM
dc_mann8's Avatar
dc_mann8
why did you double post that? but no generally a .1 off your 60 foot means about .2 off your 1320
Old Sep 5, 2005 | 11:25 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
This has been a somwhat debated topic as of late. MPH is a reflection of how much HP the car is making. The thing is, even with a great 60' the car may not have the power downtrack to make the run a good one. Gennerally a .1 reduction in 60' will result in around a .15-.2 gain in the 1/4, however with only a 94 mph there might be other things that need to looked at.
Old Sep 5, 2005 | 11:43 PM
dc_mann8's Avatar
dc_mann8
what should i be doing for mods now then??? and it was ona hot day..next race is october 15th so should be cool weather.
right now its a 1990 lx
its a 5 speed, short shifter, king cobra clutch, deleted smog pump, no air silencer, electric fan, ceramic shorties, 2.5 h pipe, flows with turndowns, 3:73 gears, and Mickey Thompson slicks. i hope to run a high 13, i currently ran a 14.71 at 94.68 and a 2.301 60 foot, which is a pretty bad 60 foot.
JD what do you think i will run now?? with the slicks.
Old Sep 5, 2005 | 11:50 PM
dan's Avatar
dan
ORIGINAL: dc_mann8
sorry i must have accidentatly did that. Maybe im wrong though.
Old Sep 6, 2005 | 12:31 AM
JD1969's Avatar
JD1969
ORIGINAL: dc_mann8
Tough to say, I would really like to see a 4.10 gear, at least an Explorer intake and possibly under drive pulleys. Where is the timing set at? Also try and get the car as light as possible, get ride of the back seat, jack and spare etc. I think the slicks will give you maybe .4
Old Sep 6, 2005 | 12:44 AM
Phillyblunt474's Avatar
Phillyblunt474
ORIGINAL: JD1969
ORIGINAL: dc_mann8
I may be wrong but i was underthe impression that 3.73s in the fox feel like the 4.10s in the new generations?
Old Sep 6, 2005 | 01:01 AM
dc_mann8's Avatar
dc_mann8
i was running full weight, spare, jack, etc. i think its heavier than it should be.. gonna put old wheels on the front too cuz i have heavy 17x9s on there now. also timing is only stock so im gonna bump it up.
