Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
pull the wheels
Old Sep 27, 2005 | 10:35 PM
Drive85mustang50's Avatar
Drive85mustang50
Default pull the wheels
I am Building a 331 stroker,comp cams roller cam 286 dur. 596 lift,11.0:1 comp. Vic. Jr. Heads and intake. I am hopeing for over 400 hp. I have a 5spd. the Car with me in it and 1/4tank of gas is 3100 lbs. i have steeda adjustable control arms i am putting in a 8 point roll cage and i am putting in a traction bar on the rearend. I should be able to get some sick traction.
-will i be able to pull the wheels? i just have to launch at my max torque right?
the rest of the specs are below
Old Sep 27, 2005 | 11:06 PM
Demon 340's Avatar
Demon 340
Administrator
Default RE: pull the wheels
maybe...its hard to say..it really depends on the traction...are you going to run slicks? every once in a while ill get the LF up a little...but its no more than a hop...however my car weighs over 3700lbs
Old Sep 27, 2005 | 11:09 PM
OneGearhead's Avatar
OneGearhead
honestly......unless you have a FULL suspension, i dont see the front wheels coming OFF the ground............good weight transfer, sure, or just spin the tires unless youre gonna be running full slicks. who knows. try it out and let us know. either way, youre still gonna have a fast car(at least it seems that way)
Old Sep 27, 2005 | 11:43 PM
seight311's Avatar
seight311
I wasn't on the outside of the car so I can't gaurantee this but... One of my parents friends had an 84 with a 351W and wide *** street tires, Griffin radiator, gutted interior, short throw (I think batt relocation too)and other basic engine mods. We estimated he would have run about a solid 12 and one time we took off good on a road, that always had races going on so it had a decent amount of rubber on it already for about 60 ft., and I know we at least got 1 wheel off the ground maybe both all I know is all I seen was mostly sky. Like I said I obviously wasn't outside the car so no one could see if we got both off the ground or not.
Old Sep 28, 2005 | 02:55 AM
Drive85mustang50
Ya i dont know if 275s are wide enough or if i will have the torque to get them up but hey i can dream right ?hahaaha
i will let you know if i ever do and post a video but it wont be for awile because the motor is still in the building proces
Old Sep 28, 2005 | 02:57 AM
Drive85mustang50
I have seen guys do wheel stands with drag radials but they where BIG.
Old Sep 28, 2005 | 02:26 PM
EADracing's Avatar
EADracing
its all about the suspension. Buddy of mine stood the wheels in his 90 coupe on MT DR's. Car had full suspension and a panhandle 306
Old Sep 28, 2005 | 04:51 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: seight311
There is no way that you got a wheel up on the street with a wide street tire. Most likley the front sway bar was off the car and it got a lot of weight off the front but there is no way a 12 second car will get the wheels up an the street with a regular street tire.
Old Sep 29, 2005 | 02:10 PM
C/Note's Avatar
C/Note
I ♥ Acer
heres me before i sprayd it out the hole..
Old Sep 29, 2005 | 02:57 PM
seight311's Avatar
seight311
I wasn't driving, and like I said I don't know if we did or not, I was in the car, can't really see if the or either of the tires came off the ground.
