Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
1/4?
Old Sep 28, 2005 | 11:18 PM
jthorn9's Avatar
jthorn9
The Godfather
Default RE: 1/4?
Yea dude you should run at worst 15s all day. You should adverage in the mid 14s, but if your real good you might be able to land in the high 13s, but don't count on that.
Old Sep 29, 2005 | 04:25 AM
Dave2000GT's Avatar
Dave2000GT
Default RE: 1/4?
ORIGINAL: 97vette
Should do better than that. A 5.0 will run about a 14.9 to 15.2. Your 4.6 has quite a bit more power than the 5.0.
Since when do early 4.6's have more power than a 5.0 ?!?! LOL
They have MAYBE the same peak power, but less torque and way less low end.
Regardless, the car in question here should run in the high 14's with the gears and H pipe.
Old Sep 29, 2005 | 11:04 AM
97vette's Avatar
97vette
Default RE: 1/4?
I had a 1987 GT and the mechanic told me that the 5.0HO was 216hp. I was also told that the 4.6 was 265hp in the GT.
ORIGINAL: Dave2000GT
ORIGINAL: 97vette
Old Sep 29, 2005 | 11:26 AM
EADracing's Avatar
EADracing
Default RE: 1/4?
ORIGINAL: 97vette
ORIGINAL: 97vette
YOur mechanic was wrong
Old Sep 29, 2005 | 01:04 PM
757GT's Avatar
757GT
I ♥ Acer
Default RE: 1/4?
Low 15s, high 14s at best. The 4.6 with p.i. heads was rated at 260, non p.i. heads were rated between 215 and 225. The 5.0 were rated in the same range. The bullitt with was rated at 265hp.
Old Sep 29, 2005 | 03:46 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
Default RE: 1/4?
ORIGINAL: 97vette
No **** LOL.
No offence intended here dude, but non PI 4.6 = turd. You will be lucky to run 15.0 or high 14s on street tires with your mods.
You should still have fun though.
Old Sep 29, 2005 | 04:16 PM
97vette's Avatar
97vette
Default RE: 1/4?
Then what does the 4.6 have for hp?
ORIGINAL: MikeHawke
ORIGINAL: 97vette
No **** LOL.
Old Sep 29, 2005 | 04:59 PM
757GT's Avatar
757GT
I ♥ Acer
Default RE: 1/4?
Read post 15 which was mine, you will find the answer.
Old Sep 29, 2005 | 06:24 PM
MikeHawke's Avatar
MikeHawke
Default RE: 1/4?
ORIGINAL: 757GT
except that the bullitt was rated at 270 LOL.
I have heard that the PI 4.6 was actually re-rated around 270-275ish buty have never seen any back up for that. Personally, I doubt it. They are only dynoing 230s to the wheels and that does not equal a 275 hp engine.
Here is 757s quote.....
Old Sep 29, 2005 | 07:11 PM
757GT's Avatar
757GT
I ♥ Acer
Default RE: 1/4?
Bullit was rated 265 when it came out, my friend has one, they might have re rated them later though.
