Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
here chew on this
Old Nov 13, 2005 | 01:19 PM
Demon 340's Avatar
Demon 340
Administrator
Default RE: here chew on this
i was not there, but my dad was running my car, and he said that his 60s were bad all night also. befoe i moved, i could get into the 1.6x range, but as they evidently werent prepping the track very well, and the fact that my QTPs are two years old, it just wouldnt grip. assuming that you mean 26x11.5x15, i run the same tires, and ive had great luck with them until this year, but as said, the wear holes are gone, and they look like a full slick now, and as the rubber has gotten a bit hard, theyve become useless.
Old Nov 13, 2005 | 02:29 PM
Mach1's Avatar
Mach1
First of all VERY nice times....but sry that car is not stock....not even close.
Old Nov 13, 2005 | 02:38 PM
HC_CrAzYHoRsE's Avatar
HC_CrAzYHoRsE
ORIGINAL: Mach1
i wouldn't say the car is stock either but definetly close ...the point is no power-adders and no engine work, so basically the motor is stock.
Old Nov 13, 2005 | 03:45 PM
nanaki's Avatar
nanaki
Retired MF Moderator
the arguement is stock though. you can get a pre-98 GT into the 13s with no "power adders".
Old Nov 13, 2005 | 05:18 PM
Quik's Avatar
Quik
how isnt it even close???? all it has is OR pipe and flows and K&N...fawk it has gears out of a Mach1. take those away from me and im still 13s. that **** only added liek 15hp if that and gears maybe 1.5 tentsh. still 13s!!!!!!!!!!!!!!! and some of you with machs and **** cant runs those times with your cars. are just a joke!!!!! learn how to drive go on a diet and drive it liek you stole it
ORIGINAL: Mach1
Old Nov 13, 2005 | 05:19 PM
Quik's Avatar
Quik
they are used tires. they sat outside for over a year and then some. so they are pretty hard. also they were pinched on a 7' rim
ORIGINAL: Ride Of The Month
Old Nov 13, 2005 | 05:22 PM
Quik's Avatar
Quik
no the motor is stock, tranny is stock, shifter is stock, suspension is stock, headers are stock, igntion is stock, pulleys are stock, Rad is stock, Dist is stock, rear end is stock with 355s, car is rull weight. air intake is stock. only OR pipe and flows!!!!!!!! still has smog, still has AC still has PS
it is a manual window, manual lock, none tilt wheel car but it has GT seats which are heavier then the stock LX seats.
ORIGINAL: HC_CrAzYHoRsE
ORIGINAL: Mach1
Old Nov 13, 2005 | 05:50 PM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
??[8D]
but hey crazyhorse,, its not like im jumping up and down saying this is exactly waht happend, once he gets his video, and proves the car is stock and still at least 13.99, then i'll believe him
Old Nov 13, 2005 | 05:54 PM
Quik's Avatar
Quik
once the dude who filmed it gets it hosted ill post the video. i think there is one of me hitting 13.9 cause i spun and bogged second. then he has my 13.38 and i think hegot my 13.4
i seriously have nothing to gain by lying. i went out with a car i bought my dad for his Bday. wanted to see what a stock car could do with me driving and just OR pipe and flows with 355s.
i added the 355s for my dad. he hasnt driven a stick in about 30 yrs so with the 308s he had a hard time on the hills around here
Old Nov 13, 2005 | 06:18 PM
Demon 340's Avatar
Demon 340
Administrator
with the work done to his car, with a good driver, at PRP i could see him getting into the 13s...
but the fact of the matter is that without the work that you do have done, the car wouldnt be in the 13s, or at least not the 13.30s/40s. gears made a tremendous difference on my car...
