Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
does torque decide who wins the 1/4
Old Feb 1, 2006 | 10:31 AM
SpecterGT260's Avatar
SpecterGT260
Default RE: does torque decide who wins the 1/4
ORIGINAL: 01SilverGT
There are too many factors that determine who wins a race. And I'm not gonna mention all of them.
I think hes asking "all other things being equal"
The torque is just the highest number of of torque the engine hits, reguardless of engine speed.
HP is a power measurement. Its work over time. and work= force times distance. Basically, HP is how much work (moving the car) can I get done in a certain ammount of time.
HP isnt as easy as plugging torque into an equation. Its for this reason that 4 cylinders can kill us with hp/liter but we win in torque/liter.
so, all things being equal, same car weight, same traction same HP and same driver gasket a torquier car is better for a race.
Old Feb 1, 2006 | 11:05 AM
angcobra's Avatar
angcobra
those that understand what you measure is torque and HP is just a caculation have it right. All the changes you do to your engine is to change the torque output and at what RPM range it makes the most torque. Movng the torque higher in the RPM band will raise HP numbers because of the math. The key to quick ETs is to match the peak torque with the RPMs you run. Ideal would be to have a flat torque curve that matched the RPMs from shift to shift. Most push for higher HP (higher torque at higher RPM) to match with top speed at trap.
Old Feb 1, 2006 | 11:50 AM
24s2k7's Avatar
24s2k7
Gearing and weight also decide the 1/4.
ex. s2000 vs 350z
Same times in the 1/4
350z has way more tq and more hp/lb ratio
s2k weighs less and has better gearing for the 1/4
Both are equal in the 1/4
Old Feb 1, 2006 | 12:19 PM
DILO2001GT's Avatar
DILO2001GT
I ♥ Acer
no. the one with the lowest time is what wins the 1/4
Old Feb 1, 2006 | 06:06 PM
Driver72's Avatar
Driver72
Everything else being equal:
one car has 200 hp and 250 lb-ft torque,
the other car has 250 hp and 200 ft-lbs less:
Car with more Torque wins 1/8th
Car with more Horsepower wins 1/4
Old Feb 1, 2006 | 06:11 PM
angcobra's Avatar
angcobra
ORIGINAL: Driver72
Not sure I understand your logic.
Old Feb 1, 2006 | 06:25 PM
Guest
Guest
Posts: n/a
ORIGINAL: angcobra
ORIGINAL: Driver72
Code said it best.
ORIGINAL: code3GT
TQ gets you going and HP keeps you going.
TQ gets you off the line because it's a low rpm "function", generally speaking.
Where as hp takes over in the upper RPMs of the power band. The car with more torque will push through the 1/8th faster, the car with more hp will push through the 1/4 faster. After the eighth you're spending more time in the upper power band.
Closkey's Avatar
Closkey
ORIGINAL: 03YellowPony
ORIGINAL: Closkey
Horsepower wins brags
Torque wins drags.
So what you're saying is, if one car had 500RWHP and 400RWTQ, and the other has 400RWHP and 500RWTQ the extra 100 RWHP don't matter? Dude..you seriously need to reconsider that little ditty. There are TOO many variable to simply answer the question yes or no.
The hp will make a difference.
There are too many variables, maybe even enough to take an old saying with a grain of salt.
Old Feb 1, 2006 | 06:33 PM
angcobra's Avatar
angcobra
ORIGINAL: 2000Si
ORIGINAL: angcobra
ORIGINAL: Driver72
Code said it best.
ORIGINAL: code3GT
Torque is always higher than HP up to 5250 RPM above 5250 RPM HP is always higher than Torque. And HP will always equal Torque at 5250 RPM. It has to be this way becasue HP = Torque X RPM/5250
In my car, I turn it to 6200 RPM to shift and finish the 1/4 trap at 6200 rpm. If I use 1st and 2nd gears for 1/8 and 3rd for 1/4, how would I spend more time at high RPMs after the 1/8th?
Old Feb 1, 2006 | 06:37 PM
angcobra's Avatar
angcobra
Sure does seem like we have been through this one before.
