Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Subaru Legacy GT
Old Feb 5, 2006 | 05:01 AM
Guest
Guest
Posts: n/a
Default RE: Subaru Legacy GT
It's basically an 06 WRX engine with a few extra pounds of boost, the next step for that car would be an STI turbo.
Old Feb 5, 2006 | 05:09 AM
1BAD3V's Avatar
1BAD3V
ORIGINAL: 2000Si
That would be sweet and a total sleeper. Hmmmm....idea.
Old Feb 8, 2006 | 03:15 PM
Driver72's Avatar
Driver72
Um, that's not exactly true.
If you were going to say anything, you'd say the
06 WRX is basically the 05 Legacy GT engine.
BUT, that wouldn't be true either.
The 06 WRX however IS the Forester XT engine/turbo with
the Legacy GT transmission but with a 3.70:1 final drive vs. the LGT's 4.11:1
The Legacy GT engine is a derivative of the WRX STI engine...but there is some changes.
The Legacy GT engine uses different heads and cams and a slightly smaller turbo that makes
1.0 psi less boost. The LGT also has a 6500 rpm redline to the STI's 7000 rpm's.
The Forester XT's engine is similiar to both but also has different heads and and even smaller
turbo than the Legacy GT's.
The 06 WRX uses this version of the 2.5 F4
The 06 WRX and Forester XT's version allows for slightly higher compression ratio than the
Legacy GT, but again it has 11.6 psi of boost from the smaller turbo compared to the LGT's 13.5 psi.
The STI also uses the largest intercooler. The LGT uses a different one, as well as the WRX/FXT.
So even though the 2.5 F4 is essentially the same, there are difference between the Subaru models.
Only the 06 WRX and 05/06 Forester XT use essentially the exact same set up of the engine.
Why Subaru did this??
Beat the h3ll out of me. To me would seem MUCH easier and less expensive to have just two version:
The STI version and then the LGT version.
The 06 WRX and FXT would get the LGT's engine but "detuned" a bit (maybe with 1.5 psi less boost) in
order to keep the LGT and STI as exclusives.
What's really funny is that in performance testing of the Legacy GT, the 06 WRX, the Forester XT.
They all pretty much perform IDENTICALLY in the 1/4 mile now. So even though Subaru made all
these changes with 3 different versions of the 2.5 F4 engine, with the exception of the STI the other
models are pretty much equal in performance under 100 mph.
Above that speed, the Legacy GT pulls away a bit from the 06 WRX, and a bit more from the Forester XT.
The LGT has a slight horsepower advantage, better gearing for acceleration, and better aerodynamics over the 06 WRX.
But the 06 WRX weighs less, so the LGT's advantage is still there, but slight.
Same with the FXT, which is better geared (4.44:1) than the LGT for acceleration, but it's a brick in the aerodynamics arena.
Driver's race below 100 mph (but with equal driver's would give a slight advantage to the LGT)
then above 100 mph LGT > WRX = FXT
Old Feb 8, 2006 | 11:46 PM
92hatchLX's Avatar
92hatchLX
My buddy got one for his GF, says that he's gotten it up to 140 and still had plenty of rpm to play with.
Old Feb 8, 2006 | 11:57 PM
Guest
Guest
Posts: n/a
ORIGINAL: Driver72
I said basically, as in it's the same basic platform. EJ25T. I didn't say exactly the same.
Old Feb 9, 2006 | 10:22 AM
1BAD3V's Avatar
1BAD3V
ORIGINAL: 2000Si
ORIGINAL: Driver72
I think he just wants everyone to think hes smarter than you. Thats what I think. LOL.
Old Feb 9, 2006 | 04:02 PM
Driver72's Avatar
Driver72
ORIGINAL: 01SilverGT
Hey now, that's not true.
I just figured if I was going to correct a statement, I might
as well be thorough.
Old Feb 10, 2006 | 12:11 AM
Guest
Guest
Posts: n/a
As far as the whole thing explaining it... I'm an avid fan of Subarus... but half that shiz confused me.
But as far as I'm concerned what I said was right in the way that I worded it.
orion6g
Oct 14, 2005 02:00 PM
JT76
Sep 17, 2005 01:19 PM
919Maniac
Jun 3, 2005 10:52 AM
Driver72
May 29, 2005 10:12 PM
