Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Racing weights
Old Feb 3, 2004 | 01:23 AM
RJM02GTDrag's Avatar
RJM02GTDrag
Default Racing weights
I just learned that it is bad for a late model Mustang fuel pump to run with less than a 1/4 tank of gas. Does anybody consider this, I mean we take out the spare tire but the difference between a full tank and empty could be 100 lbs, do you guys figure this at the racetrack?
Old Feb 4, 2004 | 03:53 AM
Deleted User's Avatar
Deleted User
I ♥ Acer
Default [Deleted]
[Deleted by Admins]
Old Feb 4, 2004 | 06:04 AM
Guest
Guest
Posts: n/a
where did you hear that from and why would it be bad for it? It's set in the bottom of the tank so it's gonna suck gas until the tank is completely dry. Don't listen to stupid people. <img border="0" src=smileys/smiley2.gif border="0"></p>
EDIT: Language... please watch that... thanks!
~Amanda<edited><editID>Admin</editID><editDate>38027.9259837963</editDate></edited>
Old Feb 4, 2004 | 09:37 AM
SpeedRicer's Avatar
SpeedRicer
<IMG src=smileys/smiley29.gif border="0">...i believe the tank also has baffles in it to get rid of this idea</P><edited><editID>SpeedRicer</editID><editDate>38021.3184837963</editDate></edited>
Old Feb 4, 2004 | 11:15 AM
RJM02GTDrag
I read it on another thread on this forum- stated that fuel is needed to lubricate and cool the fuel pump, less than 1/4 tank would shorten life of fuel pump was what was said, oh well cant believe all you read.
Old Feb 11, 2004 | 08:51 PM
vfast's Avatar
vfast
I ♥ Acer
the fuel is needed to cool the pump right but your not going to drive 4-5 hours on a 1/4 tank of gas right? I FILL MINE up on sunday by friday I have a 1/4 tank to go play on sat, sunday
Old Feb 13, 2004 | 01:45 AM
ricekiller2003's Avatar
ricekiller2003
I'm not sure all that gas would make a hundred pound difference <IMG src=smileys/smiley5.gif border="0">
Old Feb 13, 2004 | 02:28 AM
pSicho's Avatar
pSicho
Well, depending on grade a gallon of gas weighs anywhere from 5.8 to 6.5 pounds. Seeing as how a stock Mustang uses 87 octane, we'll go with the lightest amount...5.8 pounds</P>
How much does a GT hold? I went to Ford.com and it said 15.7 gallons.</P>
5.8 pounds*15.7 gallons=91.06 pounds of gasoline when it's full.</P>
3/4 tank would weigh 68.295 lbs</P>
half tank would weigh 45.53 lbs</P>
1/4 tank would weigh 22.765 lbs</P>
Almost a 70 lb difference will help to reduce the ETs, but not by much, but the other part of it is you also don't have that extra 70 lbs sloshing around.</P>
</P>
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
guitarman376
Sep 30, 2015 05:54 PM
