Suspension Ask all of your general suspension questions here!
Help with Koni STR T Install
Old Apr 24, 2011 | 02:03 AM
jojo2003's Avatar
jojo2003
Default Help with Koni STR T Install
Hello, looking for some help with the front struts. Mainly the issue is with the bump stops. According to maximum motorsports website these have bump stops on them. So I really just need some clarification. For some reason when my mm caster camber plates where install they didn't put the bump stops in on the stock strut. So I have found some MM bumpstops from a local person. Do I just slide the mm bumps stop onto the strut, or do I need to get the stock bumpstop off of the stock dustcover and use it with the mm bumpstops on the new koni's? Also should I be ok riding on the stock dustcover and stock bump stop until I get the MM bumpstops? Thanks for any advice that you can give.
Link to the struts-
http://www.maximummotorsports.com/st...b9f95b4f824889
Old Apr 25, 2011 | 09:14 AM
madmann26's Avatar
madmann26
Link to the struts-
I don't know about the Koni's but with my H&R Spring install, the instructions specifically said to trim about 1/4-1/2in of the bump stop off.
It makes since to trim the stockers or use new shortened bumpstops on the struts.
mtgldr
Feb 3, 2024 09:00 PM
Sep 10, 2015 08:39 PM
RWHEELS
Sep 5, 2015 03:42 PM
Luke9222
Sep 4, 2015 06:46 AM
