boxing 4-link?
You can weld the OEM ones, but won't do you a lot of good, I'm afraid
Depending on what you are looking to do in your ride, you need to make sure that the LCA's you do get, will suite your needs. When you are ready to go, pop back in and revive THIS thread and will be happy to help you with a proper decision
Jazzer
Jazzer
Because you read about it on the internet isn't a good enough answer by itself.
As a hint, if you're not about to pull the LF wheel on launch, you won't benefit much by doing it (if at all). At best, it won't affect the rest of your driving either way, so think about question #1 ↑↑↑ some more.
Once you're pulling wheel(s) and the car starts rolling over a LOT more from engine torque reaction, you've got a different situation and you'll need to do something, which would maybe include some local chassis strengthening as well. Once you fix a known or suspected weak link, some other part then becomes the new weak link (on the Fox platform, that generally means torque boxes).
Norm
The first question that needs to be answered is "Why do you think you need to do this mod?"
Norm
Norm
Yes... if you plan on launching your ride, you are best to get some TB reinforcements for sure. Pretty sure the LCA must be removed to do this work, so do yourself a favor and get some LCA's suited for your needs at the same time. This will (should) eliminate your wheel hop and may can pull the quads out at the same time as well.
Jazzer
Jazzer
