Suspension Ask all of your general suspension questions here!
Some Control Arm Questions
Old Nov 27, 2011 | 10:47 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Norm & Explosive... I found the MMRSB to be a wonderful option, when looking to increase stiffness out back.
I started with the MMRSB #4 which is a slight bit stiffer than the '99~'04 GT bar at its softest setting of 4 positions (can no longer find the chart that explained all this online). Since I wanted more bar, this was the logical place to start. I have gone up to a #5 bar and up to the next to last stiffness setting.
This progression has told me that there is minimal change with the upping of stiffness, but am happy that I didn't have to buy a completely new sway bar EACH time I was unhappy with the result. I also like that the bar works to keep the axle relative to the body, rather than the LCA's to each other. This makes a more consistant response in body roll, when one or the other tires hits a rut or bump during a corner.
Jazzer with an FYI & FWIW post for his pepes
Old Nov 27, 2011 | 06:53 PM
UPRSharad's Avatar
UPRSharad
Former Sponsor
Hahaha! Jazzer reppin' my set!
Anyway, Yep, I think Pro Series uppers and Pro STREET lowers with swaybar tabs are a good street/strip combo!
Old May 17, 2012 | 08:58 AM
van-swink85's Avatar
van-swink85
Iim so confused
Old May 17, 2012 | 05:27 PM
Jazzer The Cat
Retired Moderator
Back to simple....
The rear control arms you listed are going to be fine for DD and great for 1/4 mile use. They WILL add lots of NVH, but this is the trade-off for upgrade of suspension for hard use.
Does that answer your questions now?
Jazzer
GimpyHSHS
Sep 18, 2015 12:27 PM
FivePointToTheOh
Sep 14, 2015 03:35 PM
Dragonus18
Sep 9, 2015 01:21 AM
cbird1177711
Sep 2, 2015 04:12 PM
