Suspension Ask all of your general suspension questions here!
Installed steeda sport springs
Old May 21, 2012 | 04:00 PM
Andy13186's Avatar
Andy13186
Default Installed steeda sport springs
I checked how far my bumpstops are from touching the frame, and its only half an inch or so
should i cut them? I went for a ride and didnt notice them hitting, but it definatly seems like they will hit when you look at the space..
Old May 21, 2012 | 07:50 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
They can be cut a bit, but not sure how much. Get it up in the air and measure the clearance of EVERYTHING that would be in the path of hitting something else and see what kind of room you have. I am sure someone out there knows just how much you can cut, but I don't
Jazzer
Old May 25, 2012 | 04:01 PM
SteedaBrandon's Avatar
SteedaBrandon
Former Sponsor
I wouldn't say that you need to cut them unless you drive regularly on terrible roads.
Old May 26, 2012 | 02:42 AM
Forty-two's Avatar
Forty-two
I've also put in the steeda springs, and the roads here tend to be terrible.
The pipes of my exhaust regularly hit the frame somewhere when driving.
How much can/should the bumpstops be cut? And will it help?
Old May 27, 2012 | 12:12 PM
fluid1's Avatar
fluid1
If you are already hitting the exhaust on the frame, cutting the bumpstops should just make the problem worse. The bumpstops are there to prevent you from hitting the frame or anything else, and if you are with full bumpstops, then you will with shortened bumpstops. I'd suggest a possible bumpstop upgrade to a harder material and/or an upgrade to stiffer or adjustable shocks.
Old May 28, 2012 | 10:12 AM
Forty-two's Avatar
Forty-two
Thanks for the response. I had the problem with the exhaust since I converted to duals, but only on the left side where some bar is closer to the pipes than on the right. Now both sides are affected
I do have Konis. Will try to turn them a little stiffer and see how it works. I don't want to lose much comfort though.
Old May 28, 2012 | 01:51 PM
UPRSharad's Avatar
UPRSharad
Former Sponsor
suspension doesn't make the exhaust hit the body.
I cut the top nub off of the bump stops on my S197. Made it ride much nicer because they had been hitting the body like crazy.
Old May 29, 2012 | 09:39 AM
Forty-two's Avatar
Forty-two
But wouldn't it be like this: when the bumpstops hit the frame that the exhaust is also moving up and down a bit and so it hits the body too? I only have this when the road is ugly. I'll try to make a pic where my pipes pass the body too close
Old Jun 4, 2012 | 10:37 AM
UPRSharad's Avatar
UPRSharad
Former Sponsor
Exhaust moves with the body.
Old Jun 5, 2012 | 01:56 AM
Forty-two's Avatar
Forty-two
I know that it does. It was only my first assumption that it's the exhaust, as it's only half an inch away from the panhard support bar.
If that's what is right above the stock panhard bar.
Granatelli Sales
Jan 20, 2020 12:34 AM
carid
Jul 8, 2016 09:55 AM
Luke9222
Sep 4, 2015 06:46 AM
whatsup62
Sep 3, 2015 01:38 PM
Sep 2, 2015 08:40 PM
