Suspension Ask all of your general suspension questions here!
REAR SUSPENSION
Old Jul 12, 2017 | 10:47 AM
damouth's Avatar
damouth
Default REAR SUSPENSION
I HAVE A 2005 mUSTANG GT, LOWERED... I HAVE A 295/45/18 ON THE BACK, THEY TUCK AND LOOKS GOOD, BUT THE FACTORY SHOCKS WITH 150K MILES TEND TO LET THE FENDER RUB, ONLY ON THE RH SIDE WHEN I HIT BUMPS..... ANY SUGGESTIONS TO WHAT KIND OF SHOCK I COULD BUT ON THAT WOULD TIGHTEN UP THE REAR. NOTE: IM NOT WORRIED ABOUT HOW IT RIDE, I UNDERSTAND THAT WITH A TIGHT SHOCKS ITS GONNA FEEL LIKE IM RIDING A GO KART, BUT IM GOOD WITH THAT.... DOES ANYONE THINK THE FACTORY SHOCK REPLACEMENTS WOULD BE OK?
Old Jul 12, 2017 | 05:52 PM
zinc02gt's Avatar
zinc02gt
I have Strange Engineering 10 way adjustable shocks and struts with Ford K springs on my '11. It's practically the same suspension anyway. On the street I run 315/35/20's in the rear and have rub only on hard/steep drop off.
You can adjust these things to be stiffer or softer depending on how you want it to ride simply by turning a **** on the tubing. They're relatively cheap as well. I believe I found mine on LMR.
Also, rubbing is very common with a lowered 3 link since the rear end shifts slightly depending on flex.
Old Jul 13, 2017 | 10:31 AM
Z28KLR's Avatar
Z28KLR
New shocks may help to some extent but they won't stop the axle and suspension from moving to the point where your tire rubs. May wanna consider having the fenders rolled.
I'm not too familiar with the S197's 3 link rearend setup, but the side to side shifting may also be curable by going to aftermarket control arms with stiffer bushings. Consider that the stock 12 year old soft factory rubber bushings may be worn/deteriorated and contributing to this issue.
Old Jul 14, 2017 | 03:53 PM
damouth's Avatar
damouth
THINK IM GONNA TRY THE SHOCKS FIRST, THEN IF THAT DOESNT MAKE BETTER THEN GO WITH CONTROL ARMS AND ADJ PANHARD BAR
