SVT Forums
got a question
Old Mar 2, 2006 | 07:31 AM
stang01cobra's Avatar
stang01cobra
Default got a question
01 cobra has the same engine like 03 and 04 so put a supercharger on a 01 will make it as fast as the 03's and 04's.......?
Old Mar 2, 2006 | 01:54 PM
CobraSnake's Avatar
CobraSnake
Default RE: got a question
does it have the same engine?????? Did you do research.
Old Mar 2, 2006 | 01:56 PM
Black04COBRA's Avatar
Black04COBRA
Same "block" yes.
Different internals. You would need to forge your internals to have it handle the SC.
Old Mar 2, 2006 | 04:35 PM
Wicked's Avatar
Wicked
I thought the 01's had Aluminum blocks and the 03/04 had cast iron block?
Old Mar 2, 2006 | 04:50 PM
angcobra's Avatar
angcobra
NO!
They are totally different engines. The 01 is an aluminum block and the 03/04 is cast Iron.
Also, before you throw a SC on an 01 Cobra, consider it has 9.8:1 compression ratio, not saying you can't do it just saying, it is completely different from the GT stock CR.
Old Mar 2, 2006 | 05:39 PM
Wicked's Avatar
Wicked
Thats what I thought, What C/R can you run on an 01 with only forged internals?
Old Mar 3, 2006 | 12:53 AM
roushracingmustang's Avatar
roushracingmustang
I think you can run 8 to 10 pounds of boost the 99 & 01 cobras do have forged cranks and rods
the pistons are cast with the slicone side skirts I would check with Vortech or Procharger?
Old Mar 5, 2006 | 03:39 AM
stang01cobra
thanks for the info guys.....but when i saw an 03 cobra with the stock SC so the only different i saw there was a SC on the top of the intake manifold where i have a cobra symbol so thats y i was kinda curious and asked.
Old Mar 7, 2006 | 11:10 PM
TTSvtCobra17's Avatar
TTSvtCobra17
not the same motor. different everything. from the block all the way up to the heads. even the fuel system and ingition system is different. not counting all the stuff youll break with the 01 cobra drivetrain
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
