SVT Forums
Gt to a Cobra?
Old Mar 7, 2006 | 06:59 PM
TimmyGt's Avatar
TimmyGt
Default Gt to a Cobra?
does anyone know what it would take to change a GT engine to a Cobra engine?
Old Mar 7, 2006 | 07:28 PM
AmericanMuscle4.6GT's Avatar
AmericanMuscle4.6GT
Default RE: Gt to a Cobra?
yea..........im sort of a newb.........but first of all the GT block is iron (i think) and the cobra block is aluminum, so nothing you can do about that.
otherwise, 4V heads and a supercharger pretty much is the main difference. I am too much of a mechanical nOOb to say whether or not a head swap like this would be practical.
MORE KNOWLEDGEABLE PEOPLE PLEASE STEP IN TO CORRECT ME IF I AM WRONG.
Old Mar 7, 2006 | 10:32 PM
TTSvtCobra17's Avatar
TTSvtCobra17
it would not be too hard of a swap, but the only way i can see this swap worth it is if you get the 03/04 cobra cast iron block. the 99/01 blocks are aluminum and wont hold up to alot of spray or boost. unless you build it up with good forged internals.
Old Mar 7, 2006 | 10:35 PM
97slobra's Avatar
97slobra
ORIGINAL: TTSvtCobra17
The96-98 teksid blocks can handle up to 1k hp and there aluminium
Old Mar 8, 2006 | 01:52 AM
TimmyGt's Avatar
TimmyGt
is that the same block thats in the 99-01?
Old Mar 8, 2006 | 03:08 AM
HaV's Avatar
HaV
ORIGINAL: TimmyGt
No. The teskid block was only 96-98 and POSSIBLY a limited number of 99's. There are accounts of it holding up to well over 1000hp.. Its regarded as the strongest factory block for the 4.6's and better then many of the aftermarket blocks.
It would be an easy swap... its the same demensions and most things are already in the same spot so not much relocation.. I am pretty sure the DOHC has a different wiring harness.. not 100% sure if you would need to swap computer or not though.
Old Mar 8, 2006 | 01:55 PM
TimmyGt's Avatar
TimmyGt
Im looking for a totalled cobra that I can use for parts. if anyknows where to get one let me know!
Old Mar 23, 2006 | 09:20 PM
thatsilverstang's Avatar
thatsilverstang
PMPFactoryDesigns sells a complete 03/04 cobra motor $4700.00 Remand to ford spec with factory forged part and a 3 year warranty
It includes complete bottom end with water pump, oil pump 03/04 4V cobra heads full of oil and ready to drop in.
Also as far as the wiring you may want to consider a complete 96 GT harness this will cost you much less than a cobra harness, then just burn the chip and power the harness.
hope this helps
Steve
Old Mar 23, 2006 | 09:37 PM
David_K's Avatar
David_K
its still not a SVT when you do the switch. its better to sell your GT and buy a cobra. one its real, and second youll be an SVT owner
Old Mar 24, 2006 | 01:49 AM
NaplesFL11GT's Avatar
NaplesFL11GT
I agree!
