SVT Forums
Old Oct 3, 2006 | 02:56 PM
freewilly's Avatar
freewilly
I ♥ Acer
Default .
Old Oct 3, 2006 | 05:34 PM
CobraBob's Avatar
CobraBob
Default RE: WTB 03 STOCK LOWER S/C CRANK PULLEY
FreeWilly, usually when you eat belts like that there is an alignment issue. Did you only change the lower or did you install an upper and/or idlers?
Old Oct 3, 2006 | 05:53 PM
freewilly's Avatar
freewilly
I ♥ Acer
Old Oct 3, 2006 | 05:55 PM
freewilly's Avatar
freewilly
I ♥ Acer
ORIGINAL: CobraBob
the ilder where all ready on it . before the lower , with no problems
Old Oct 3, 2006 | 09:14 PM
spray175's Avatar
spray175
I tihnk for the 6lb kit you should need a 3.5 alternator pulley. I think a 3.2 is for 2lb and 4lb kits.
Old Oct 4, 2006 | 03:57 AM
zincsvtcobra's Avatar
zincsvtcobra
I tend to hear that alot about RPMOUTLET. I was planning to buy an AFCO HE from them too, but now I'm concerned. Off the subject, but who elso carries the AFCO's???
Old Oct 4, 2006 | 09:13 AM
CobraBob's Avatar
CobraBob
ORIGINAL: spray175
Yes, a 6 lb. lower should use the 3.5" alternator pulley. I think, though, ***** has an alignment issue. I'm guessing the lower was not installed properly if the belts were fine before the install of that lower and he didn't tough the idlers or upper pulley.
Old Oct 4, 2006 | 09:16 AM
CobraBob's Avatar
CobraBob
ORIGINAL: zincsvtcobra
I recommend Lightning Force Performance heat exchangers. They have a new dual pass model now. Ask for Mark. http://lightningforceperformance.com...1374fd1b5a4f6e
Old Oct 4, 2006 | 11:46 AM
freewilly's Avatar
freewilly
I ♥ Acer
[quote]ORIGINAL: CobraBob
ORIGINAL: spray175
Old Oct 4, 2006 | 01:23 PM
spray175's Avatar
spray175
Look at lethalperformance.com, they recommend a 3.5 with the 6lb lower. Everything Ive looked at recommends that combo. I tihnk you should switch to that. I got my 4lb lower pulley in today but I dont think Im going to put it on for a while.
