SVT Forums
blower question
Old Oct 25, 2006 | 07:31 PM
ce03srt4's Avatar
ce03srt4
Default blower question
I was wondering if anybody knows whether or not an '03 cobra blower will fit on a '97 cobra motor. If not, what is the major differences in the two motors that would make it not work? Thanks!!
Old Oct 26, 2006 | 01:26 AM
CobraBob's Avatar
CobraBob
Default RE: blower question
First off, the compression on the '97 is too high for the amount of boost you'd get from a stock Terminator blower. You wouldn't want more than 5-6 lbs. The stock Eaton is around 8.5 lbs.
Old Oct 29, 2006 | 01:30 PM
ce03srt4's Avatar
ce03srt4
If the compression is to high, how come you can run a Vortech on it at 12 psi with no problem? Or even a Kenne Belle at 10 psi? Would it fit is the question I'm wanting to know.
Old Oct 29, 2006 | 04:07 PM
RedAlertlb's Avatar
RedAlertlb
would it just bolt up to your lower intake no if thats what your asking yes it will fit with alittle grinding and mod
Old Oct 29, 2006 | 04:09 PM
RedAlertlb's Avatar
RedAlertlb
go here
a guy there did it
Old Oct 30, 2006 | 12:52 PM
ce03srt4's Avatar
ce03srt4
The link didn't work. That's cool though. Just knowing that it can be done, I can make it happen. Thanks for your help!
Old Oct 31, 2006 | 10:53 AM
AllVenom's Avatar
AllVenom
ORIGINAL: ce03srt4
First of all, what Cobrabob said is correct. You can run any amount of boost you'd like to, shoot, go for broke, run 20psi. However, your engine won't last long at anything more than 8psi with your engine setup, in current form.
Anything can be done if you have the know-how and right tools and a little creativity. But knowing your limits is a whole other thing. Why not dump the money into building something else and dropping it in?
Old Nov 1, 2006 | 02:56 PM
ce03srt4's Avatar
ce03srt4
If I tune it right, then I will have no problem with 8.5 pounds. Why not build another motor, If I had enough money to do so then I would. If I can get my hands on another motor that's another story. Thanks for the input.
Old Nov 1, 2006 | 11:41 PM
cobra925's Avatar
cobra925
If I was you I would get a pro charger, vortec or KB if you want a twin screw, don't waste your time and money with an eaton of an 03/04 cobra.
Old Nov 2, 2006 | 08:38 PM
ce03srt4's Avatar
ce03srt4
I would rather do that, but messing with the '03 blower, it will cost alot less. The idea was mainly for sh**s and giggles. Either way, I would much rather go pro charger. I have installed a few of these for with friends and I was incredibly impressed.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
