SVT Forums
94 COBRA STALLING
Old Jul 11, 2003 | 12:08 AM
94BLKCOBRA's Avatar
94BLKCOBRA
Default 94 COBRA STALLING
I JUST BOUGHT A 94 COBRA WITH 81,000 MILES ON IT AND A WEEK LATER THE CAR STARTED STALLING WHEN DECELERATING AND IT IDLES ROUGH WHEN I'M AT A STOP, DOES ANYONE HAVE ANY IDEAS, THANKS!!!
Old Jul 11, 2003 | 12:31 AM
Sean's Avatar
Sean
Try a tune up.
Old Jul 11, 2003 | 01:49 PM
03SVTcobraa's Avatar
03SVTcobraa
tune up sounds logical to me too.
Old Jul 12, 2003 | 03:58 PM
94BLKCOBRA's Avatar
94BLKCOBRA
I PUT A NEW CAP,ROTOR,PLUGS,WIRES,FUEL FILTER AND AIR FILTER, NOT AS BAD BUT IDLE IS STILL ROUGH, ALSO SOMEONE MENTIONED TO ME POSSILBE VACUUM LEAK SO I REPLECED A COUPLE OF HOSES IN THE INTAKE MANIFOLD AND I NOTICED THAT THE UPPER INTAKE GASKET WAS HARD AS PLASTIC IS THIS WORTH CHANGING OR AM I ON THE WRONG TRACK.
Old Jul 18, 2003 | 05:35 PM
Redline5th's Avatar
Redline5th
Werd, or either someone snuck a cam in there <IMG src=smileys/smiley17.gif border="0"><IMG src=smileys/smiley3.gif border="0"></P>
Nah get a tuner uper </P>
Old Aug 3, 2003 | 02:06 PM
churk13's Avatar
churk13
Check your Idle air hose, it should smoothe things out.Is it stalling when you are in gear and decelerating at like 1500 rpms? Or when you roll to a stop in neutral?
Old Aug 5, 2003 | 04:03 PM
94BLKCOBRA's Avatar
94BLKCOBRA
It stalls when in neutral at a stop. Someone one mentioned the tps sensor, is that a possibility.
Old Aug 6, 2003 | 08:52 PM
churk13's Avatar
churk13
Did you check your idel air hose? Does it stall when its warm or does it just reve up and down from 300 to 700 rpms?
Old Aug 8, 2003 | 12:39 PM
94BLKCOBRA's Avatar
94BLKCOBRA
It stalls in neutral when slowing down, and it idles rough right after i crank her up, from 300-700 rpm's just as u mentioned.if i put a load on engine such as turn the wheel while i'm parked it will stall. also i'm not sure where the idle air hose is at?
Old Sep 20, 2003 | 10:35 PM
94 cobby's Avatar
94 cobby
Here my thoghts on that. one of these: vaccum leak, bad computer, timing off, or bad ignition coil
