SVT Forums
Need HELP 98 cobra advice!!
Old Nov 16, 2006 | 01:11 AM
leroy's Avatar
leroy
Default Need HELP 98 cobra advice!!
i have a 98 cobra and i just dont have the power that i want i need a blower. but thats where the help is needed what kind how big?????? i do my reasearch i just want to get some advice. I have a completle rebuilt engine with all forged internals and cams and absolutly everything. i am putting out 450 at the crank and 420 at the wheels i want about 550 to 650 at the wheels. what do you guys think?
engine:
boared out .20 times over
brandf new ford racing 8-bolt steel crank
manley 4.6 billet I-Beam rods
17cc forged dished CP pistons
mod max file-fit rings
moroso 7qt rear sump oil pan
new ford racing cobra oil pickup tube and pump
drivetrain:
new tremec t56 tranny
11" stage 3 clutch
new lightned flywheel
410 gears
Old Nov 16, 2006 | 01:35 PM
a_Alsebaei's Avatar
a_Alsebaei
Default RE: Need HELP 98 cobra advice!!
Go for a D1SC Procharger package or Hp Twin Turbo kit. That will be strong
It has to be complete with fuel sys and tuning and so on
I think that 12- 15 PSI will be Nice but not more. Still you don't have a strong short block to handle more power.
Good Luck
Old Nov 17, 2006 | 01:39 AM
leroy's Avatar
leroy
thanks for the advice boss! what could or should i do to strenghten up my short block?
Old Nov 17, 2006 | 06:21 PM
96 myztic's Avatar
96 myztic
ORIGINAL: leroy
engine:
drivetrain:
11" stage 3 clutch
410 gears
sounds more like a wish list then somethin someone would actually have. Those I beams are like triple the price of the h beams.
Also 450 at the crank and 420 at the wheels, shouldnt i be more like 385 rwp with a 450 crank? And to get 385 rwhp outta bolt ons/cams you must have a sick *** tune/ huge lope cam.
[sm=icon_beat.gif]
That being said a dsc1 will get you how ever high u wanna go in terms of HP.
Edit: Seeing that you are from danville you arent gonna pass smog tests with a DS-c1, and i dont think you are gonna want to keep takin it off every 2 years.
Old Nov 17, 2006 | 09:36 PM
mjdjkj's Avatar
mjdjkj
with the engine set up like that you can run 18-20 psi..
Old Nov 18, 2006 | 12:38 AM
7arpad7's Avatar
7arpad7
Get a Kenne Bell blower... that would make some sick torque and HP from low RPMs through the whole RPM range... just my two cents worth... It is what I will go with next summer when I have the cash... But, I will run 6 to 8 psi because my engine is stock, whereas yours looks like it can handle sooo much more... it that is your list of engine components and not a wish list...
Old Nov 18, 2006 | 03:28 AM
EBBS_96_Cobra's Avatar
EBBS_96_Cobra
Wow, if my car put out that much power I'd be happy.
Oh Cobra, when will you ever get more power? Oh right, when I get money![:@]
Old Nov 18, 2006 | 04:24 AM
leroy's Avatar
leroy
the cams are 272/272 .050
Nov 10, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
Dan04COBRA
Sep 30, 2015 11:46 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Sparks_88
Sep 8, 2015 01:06 PM
