SVT Forums
Something sounds broken...
Old Nov 23, 2006 | 01:44 AM
JamesTronix's Avatar
JamesTronix
Default Something sounds broken...
Hey guys, I have a strange sound when I take off and shift gears I hear a Faint clunk like something under the car is rising up and hitting the floor board. Any ideas?
Old Nov 23, 2006 | 02:31 AM
ponysnake99's Avatar
ponysnake99
Default RE: Something sounds broken...
check your transmission crossmember/mount first...check your motor mounts just to be sure as well
Old Nov 23, 2006 | 03:24 AM
JamesTronix
ok, anything else?
Old Nov 23, 2006 | 11:16 AM
michael12203's Avatar
michael12203
yep mine was doing the same thing. check to see if it has backlash in the rear! Mine came from the track and it became awful when i would take off it would sound like somehting hitting something in the back under the car, Had to get a new r&p
Old Nov 23, 2006 | 11:58 AM
mills281e's Avatar
mills281e
If it sounds like something toward the back of the car, it may be your rear sway bar. Mine cracked at the bend on the passenger's side when I was pulling into a sloped parking lot sideways to avoid rubbig the front facia. I couldn't find out what it was for a couple days afterward.
It sounded like the spring in a diving board after someone jumps off of it. It will not hang down though since they are so stiff.....so give it a yank to check.
Mills
Old Nov 26, 2006 | 01:54 PM
7arpad7's Avatar
7arpad7
I have had sounds like that come from my car before... Once it was the rear sway bar. It would make a loud "popping" type noise when ever the rear end saw some torsion. In other words, when I did some heavy acceleration, but especially when I would turn into a driveway or take a sharp turn... It sounds more to me like your lower control arm has a loose bolt on it. When I had this problem, it was most noted when I went from reverse to forward with a little gas (or vice-versa). The easiest way to check this problem is to just put a wrench on it... the other way to check it would be to raise the car on a hydrolic lift (taking the load off of the rear end) and then yanking on the parts down there... I about forgot... I had another run in with this type of sound. It was just the bracket that the shocks are mounted on. This is most likely not your problem unless you notice the sound when you run over some larger bumps... On a side note, I had driven my car for a while with bad motor mounts (bought the dang thing like that). The only thing that really was noticable with that is that the shifter would jiggle around a bunch... A couple things are for sure. The sound is really annoying, but most likely not that hard or expensive to fix.
Old Dec 1, 2006 | 02:11 PM
svt99redcobra's Avatar
svt99redcobra
yea, my cobra still makes noise. I thought it was the clutch because it only clunked when i shifted gears. But i replaced the clutch and tranny mount/crossmember with a energy one, and i still get the loud clunking every gear change. Between payments and insurence and gas i dont have the $'s to fix it. LOL so its going to make something else break.
Old Dec 2, 2006 | 12:34 PM
michael12203
what i thought was backlash was not my prob was in my diff bushings they were worn out every time i hit the gas and let off it would sound like something beating under thecar
Old Dec 3, 2006 | 01:20 AM
JamesTronix
Yea, I replace my diff bushings, but the noise is still there.
Old Dec 5, 2006 | 11:01 PM
JamesTronix
I found the problem. The bolt in the driver side of the rear diff mount was loose and the diff was moving up and hitting the snubber.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
KingRando
Oct 2, 2015 08:06 AM
DtRockstar1
Mustang Videos
Sep 27, 2015 07:46 PM
