SVT Forums
2001 Cobra
Old Dec 1, 2006 | 07:02 PM
02 JRClassic's Avatar
02 JRClassic
Default 2001 Cobra
Need a little help with a subject I am unfamiliar with - the snakepit. I've been keeping my eyes out for an '01 cobra vert for a few months now and have a few questions prior to pulling the trigger. My roush has ~425 crank hp, which is where I would at least like to be with the cobra. I understand the 01's have a forged crank, but should it stop there? If i were to slap a S/C on her, which I will do, would it be wise to beef up the rods and such?
For those who feel it's best to simply buy an 03/04 that has everything already taken care of, I prefer to add my own touch to the car.
Old Dec 1, 2006 | 10:05 PM
snakeman4life's Avatar
snakeman4life
Default RE: 2001 Cobra
It depends on how much power you want.8 psi is a good safe amount of boost on a stock bottom ens,and will usually be good for 425hp[or more] at the wheels.If you want more than that then it would be wise to build the bottom end.
Old Dec 1, 2006 | 10:11 PM
angcobra's Avatar
angcobra
compression is a little high on 01s to put much boost on.
Old Dec 2, 2006 | 02:42 AM
Crazyfast50stang's Avatar
Crazyfast50stang
I thought compression was 8.5??
Old Dec 2, 2006 | 02:43 AM
Crazyfast50stang
Myu bad I think its 9.5
Old Dec 2, 2006 | 03:06 AM
ponysnake99's Avatar
ponysnake99
your fine for the equal amount of hp your roush is making...a procharger will put you there and a kenny bell will be just as good...to match the roush is no problem...but anymore, then take the above advice and throw some customs in there
Old Dec 2, 2006 | 04:14 AM
02 JRClassic
The roush maxes out at 400rwhp... what is a safe amount for the bottom end on the 4v motor? Also, would an 03/04 Eaton sc be possible? I know some intake customization would be needed
Old Dec 3, 2006 | 02:52 AM
ponysnake99
the block is good to 600, the crank is good to 800, the rods are the weak point, and i wouldnt give it anymore than about 500...im not sure about the swap though (although im sure most ppl will tell u get a whipple or kb because the "heaton" isnt worth the $$), but im sure either an 03 set of heads or porting could match things up[&:]
Old Dec 3, 2006 | 02:57 AM
snakeman4life
ORIGINAL: Crazyfast50stang
Actually it's 9.85.The 5.5psi Kenne Bell 2.1L kit is good for over 400rwhp on a '01 Cobra,and 5.5 psi won't hurt anything.
Old Dec 3, 2006 | 10:36 PM
MuscleOwnzRice's Avatar
MuscleOwnzRice
roush wont even compare to the cobra once you get the cobra upgraded a bit
