SVT Forums
snake grille insert
Old Jan 11, 2007 | 06:09 PM
phillyphan56's Avatar
phillyphan56
Default snake grille insert
hey guys i have a cobra and i still have the pony in the grille. i just bought the snake but i dont know how to get the horse off. the nuts holding it in are some special nut. what should i use to get it off? it looks like an allen key hole with a small stud in the middle. thanks
Old Jan 11, 2007 | 06:20 PM
ZAXJAX's Avatar
ZAXJAX
Default RE: snake grille insert
It's a T-25 bit, you can find them at any hardware store.
Old Jan 12, 2007 | 01:05 AM
Blownsvt's Avatar
Blownsvt
my socket set had a bunch of bits that came with it and there was one in there that worked. if you have a set with various bits check those out.
Old Jan 12, 2007 | 12:03 PM
1fast50's Avatar
1fast50
torx T-25
Old Jan 12, 2007 | 12:33 PM
randyg's Avatar
randyg
I had to use a small flathead to get them loose. Where the T-25 bit would go, there was a small round pin in the center that was sticking out, preventing me from getting the bit inserted. Luckly, they weren't that tight.
Old Jan 12, 2007 | 02:26 PM
1fast50's Avatar
1fast50
thats good... at least they came out without a struggle.. Do you have to use the same screws for the Snake or do they come with the new emblem?
Old Jan 12, 2007 | 08:09 PM
CobraMac's Avatar
CobraMac
It's actually a "Tamper Proof T-25 Torx bit." That's why you see that little dot or "round pin" sticking out of the middle of it. A regular T-25 torx bit will not work on it. It will screw up the bolt if you try it with a regular torx bit. You can find the tamper-proof torx bits at any home depot.
Old Jan 12, 2007 | 08:36 PM
randyg's Avatar
randyg
I had to reuse the screws, I didn't get any in the box with the emblem.
Old Jan 13, 2007 | 01:07 AM
svt99redcobra's Avatar
svt99redcobra
ORIGINAL: CobraMac
+1
Old Jan 13, 2007 | 05:08 AM
96cobra10101's Avatar
96cobra10101
Advanced Auto has them for sure, but you can get them at almost any parts store. Hardware stores may not have them.
