SVT Forums
Cobra Pinging
Old Aug 11, 2003 | 03:55 PM
bob227's Avatar
bob227
Default Cobra Pinging
Hi, I don't know if I am doing this but hopefully someone can guide me on a problem with my 2001 cobra convertible.</P>
On hard excelleration at approximately 4500 plus RPM's the car pings and sounds like it's bad gas or a timing problem. The dealership changed the plugs, but the car only has 11,000 miles on it. I talked to a guy from a place here in California that specializes in super charging cobras and he told me that because of emotions Ford cannot do timing on the car like an after market mechanic can. Has anyone else had the pinging problem out there and what do you suggest I do to get rid of it.</P>
Thanks</P>
Old Aug 11, 2003 | 05:26 PM
Jugador1's Avatar
Jugador1
I ♥ Acer
if im not mistaken higher octane gas...could be wrong.
Old Aug 11, 2003 | 05:53 PM
Snydaleid's Avatar
Snydaleid
Use a higher octane gas and see what happens. If you're using the lower grades it's normal.
Old Aug 11, 2003 | 05:55 PM
Jugador1's Avatar
Jugador1
I ♥ Acer
yeah, now im sure cause u said it too and a friend of mine had the same problem and fixed it by buying supreme or whatever. 93 oct.
Old Aug 11, 2003 | 06:35 PM
bob227's Avatar
bob227
I am already using supreme, that is all you can run in the car
Old Aug 11, 2003 | 07:42 PM
Snydaleid's Avatar
Snydaleid
I hope this helps.</P>
http://www.corral.net/forums/showthr...hlight=pinging</P>
Old Aug 11, 2003 | 09:21 PM
bob227's Avatar
bob227
Thanks, the highest octane in California is 91, we don't have 93. I am guessing there is a timing issue with it and that the dealer will only go by what the factory setting calls for.
Old Aug 12, 2003 | 04:49 PM
Pyrro's Avatar
Pyrro
What is your A/F ratio? What mods do you have? Pinging is usually a sign of detonation which is bad especially if you have a supercharger. Usually, the factory makes up for that by retarding the timing. There's always going to be someone who uses 87 octane then floors it up a hill in 4th gear.
Old Oct 20, 2003 | 12:49 AM
RAZZ's Avatar
RAZZ
<IMG src=smileys/smiley16.gif border="0">
Old Oct 23, 2003 | 01:55 PM
cobrakid's Avatar
cobrakid
On hard excelleration at approximately 4500 plus RPM's the car pings and sounds like it's bad gas or a timing problem. The dealership changed the plugs, but the car only has 11,000 miles on it. I talked to a guy from a place here in California that specializes in super charging cobras and he told me that because of emotions Ford cannot do timing on the car like an after market mechanic can. Has anyone else had the pinging problem out there and what do you suggest I do to get rid of it."</P>
I have a 01 Cobra (stock) except for flowmasters.. and mine does that upon hard excelleration. I believe it's a normal thing. I run 93 octane. It's almost like a loud clatter. It's all those horses kicking up thier heels.</P>
-=cobrakid=-</P>
-2001 SVT Mineral Gray Vert. Flowmasters, lightbar. billet grill..</P>
