PULLY SIZE
i was woundering how pullys make u have more power i just got my cobra about 6 hours ago and i was going to order parts tomarrow and what are some chaep bolt on that will give alot of power?*
RE: PULLY SIZE
underdrive pullies or blower pullies? Blower pullies give you more power (smaller upper) because the belt can turna smaller diameter pullyfaster, increasing the amount of positive pressure forced into your motor. I'm not to sure on the lower blower pully, I think they even may go larger on that on, but think of it like gears on you old 10 speed bike, the faster you can pedal the more air you can move. Bad analaogy, but you get the point
oh, and congrats on the new ride!!!! |
RE: PULLY SIZE
good pully combos are 2.7 with 2# lower, 2.8 wit 4#, 2.9 wit 6#, and so on.
RE: PULLY SIZE
RE: PULLY SIZE
Wow, got it six hours ago and already looking to addmajor hp? I've been driving mine daily for almost a year now and the power level is JUST starting to feel like not enough! I would suggest beefing up that rear end you were mentioning in the other thread. I had bad wheel hop in mine also and figured why add more HP when I couldn't put what I already had to the ground...just my .02
But if you do decide to go the other route thenmore power to you ;) Pun intended. |
RE: PULLY SIZE
RE: PULLY SIZE
well if you whant a kit with all the stuff you will need to run highter boost and a good tune you will need one of these dyno tuned power packs from RPMoutlet.com, i would get the SCT Xcal2 tuned power pack with the 2.75 pulley and NGK pluggs its the best bang for the buck out there these days, that would get you to 440hp easy
http://www.rpmoutlet.com/03cobra.htm ohh and i port blowers also |
RE: PULLY SIZE
You can learn a TON about a TON there. Its where I learned alot about cars a few years back. |
