SVT Forums
help with heat exchanger
Old Apr 25, 2007 | 06:03 PM
Lee20ss00's Avatar
Lee20ss00
Default help with heat exchanger
where can i get the best heat exchanger and what is the bigest upper pulley i can put on a 03 cobra with heat exchanger,exhaust, intake and a tune?what rwhp will i be with all that?
Old Apr 25, 2007 | 10:01 PM
spray175's Avatar
spray175
Default RE: help with heat exchanger
Afco heat exchanger, you mean smallest pulley I think which would be a 2.76. That will put you in the 440-450rwhp range.
Old Apr 25, 2007 | 10:51 PM
PushinTheLimit's Avatar
PushinTheLimit
LFP and Fluidyne are both good brands to consider for a HE. I'm personally going with a LFP. You can run a 2.76 upper pulley like spray175 said... just make sure to get a good tune for that and the other things that you listed you wanted done. Its possible you could be anywhere around 440-480 rwhp. Thats about all you will see until you either port the Eaton or upgrade to a Whipple or KB.
Old May 4, 2007 | 01:11 AM
ry_aalderink's Avatar
ry_aalderink
i would like your stock h/e if your purchasing an aftermarket one. let me know
Old May 4, 2007 | 05:50 AM
mattmoto441's Avatar
mattmoto441
the LFP is made by AFCO
i have the afco pro series easy 30min install
Old May 4, 2007 | 12:21 PM
Blownsvt's Avatar
Blownsvt
i got my fluidyne from lethal performance.
Old May 5, 2007 | 04:22 AM
tchamber's Avatar
tchamber
Hey, thanks guys, especially to you, Golden, you inspired me to order an LFP HE. Should be here by Wednesday.
Old May 5, 2007 | 04:42 AM
mattmoto441
ORIGINAL: tchamber
good choice the LFP/Afco are easy install H/E i have the Pro series what did you go with the standard?? or PRO?
did you get it with a stencle??
Old May 5, 2007 | 08:25 PM
tchamber's Avatar
tchamber
It's the Extreme Dual Pass H/E, no stencil, I didn't look closely enough at the options, didn't see it [:@]
Old May 7, 2007 | 06:32 PM
drewsrt's Avatar
drewsrt
Nice choice. I have the LFP dual pass. I have no comparison or proof that it works any better but I've seen many threads on svtperformance. There was a test done by a member and it was said that the LFP dual pass cooled the intake temp by about 3-5 degrees over other aftermarket heat exchangers. If that's true then it's a very nice piece.
Also for the poster, I have a 2.95 pulley, bassani cat back,bassani x-pipe (no cats), JLT intake and an SCT tune and put down 447hp and 458tq. I was honestly not expecting that much power for the pulley I purchased. This was on a mustang dyno as well.
