SVT Forums
NEED HELP WITH MY 03 Cobra!
Old Jun 17, 2007 | 05:15 PM
1sicls1's Avatar
1sicls1
Default RE: NEED HELP WITH MY 03 Cobra!
it does seem to be running rich. i dont know if the previous owner had it tuned at all. i got this car from a dealership. today im gonna replace the o2 sensors on bank 1 and bank 2 and see if that fixes all these problems i got currently. i hope it does. my exhaust rattles kinda badly sometimes in lower rpms like around the 2000 rpm range im gonna see if any of the exhaust brackets are loose or missing, causing it to make those sounds when im accelerating or downshifting sometimes.
Old Jun 17, 2007 | 08:02 PM
1sicls1's Avatar
1sicls1
my room mates dad who works on fords at a dealership said its def a vacum leak. so im gonna try to fix that today. wish me luck!
Old Jun 17, 2007 | 10:48 PM
TeddyKGB's Avatar
TeddyKGB
ORIGINAL: 1sicls1
If it always happens right around 2000-2200 it is probably just "drone". The aftermarket exhaust hits a point where it begins to resonate loudly and many seem to get that right around 2K rpms.
Old Jun 19, 2007 | 11:36 PM
1sicls1's Avatar
1sicls1
i took it to a shop they replaced my fuel pressure sensor on the fuel rail. my cars fuel pressure was running at 28psi insted of 40 psi. they cant figure out why its having trouble finding idle. if u leave it on for awhile the car will just die... if i had more money if send it back to the shop to have it fixed further.
Old Jun 19, 2007 | 11:43 PM
angcobra's Avatar
angcobra
What kind of CAI does it have? I had the stall after power issue you have when I was running a MAC CAI. Changed to JLT issue went away.
Old Jun 20, 2007 | 02:28 AM
1sicls1's Avatar
1sicls1
i dont know the CAI has no markings. the mechanic took the K&N filter off and ran the car and it still had issues, then he cleaned the MAF and it still had issues. he said the way it runs it might have been tuned but he cant tell...
Old Jun 20, 2007 | 01:53 PM
PSR's Avatar
PSR
if you install a stock mid pipe and reset the battery the code will go away. or you can a set of MIL eleminators and install them that will also take care of the problem
Old Jun 21, 2007 | 03:36 AM
1sicls1's Avatar
1sicls1
could that be causing my car to turn off after it idels for a bit? or when i put it in nutral coasting it turns off too.... what can be causing that?
Old Jun 21, 2007 | 12:44 PM
CobraBob's Avatar
CobraBob
Congratulations on buying your 2003 Cobra! You're gonna love it. Since you're new to the 2003 Cobra, the FAQ page on my website will provide you some very useful info. http://www.stangshiftergaskets.com/2003_2004faqs.htm
Old Jun 22, 2007 | 04:45 AM
1sicls1's Avatar
1sicls1
thanks but i have already read that. do you guys think honestly this car is gonna be able to drive from chicago back to california in its current state. i drive it daily right now and it runs fine... should i be periniod of taking it cross country???
