SVT Forums
Please help on a 99 Cobra
Old Jun 21, 2007 | 06:42 PM
kingleo1983's Avatar
kingleo1983
Default Please help on a 99 Cobra
Im in the mists of buying a 1999 cobra with 32,000 miles on it, it has
Navigator Power Heads long block
72lb injectors
canton oil pan'
hooker header and x pipe (off road)
spec stage 3 clutch
aluminum fly wheel
3,5 inch univer upgraded to disc blower
plasma booster
raptor shift light
inn.west 10% over balancer
Anderson power pipe
max ms subframe connectors
bassani exhaust
weldon pump regulator and filter
return style fuel system
aluminum drive shaft
steeda short throw shifter
ati pro charger
brembo rotors and calipers
HRE wheels with BFGoodrich Gforce TA tires. Front has 265/35/18 and the rear has 295/35/18
5 way adjustable tokiko struts
lowering springs
373 gears
boost end fuel pressure gauges
It only has a 5-speed tranny in it, and I was wondering if I needed to upgrade to a 6-speed tremec tranny, the car puts out 640 Max horse, & 588 Torque?
I know the place the work was done at, and he is a reputible guy, Is there anything that I should look at before I buy this car, Thanks a lot
Old Jun 21, 2007 | 10:26 PM
abmtex2007's Avatar
abmtex2007
Default RE: Please help on a 99 Cobra
there is no means of needing to put a 6 speed in there. It would help to stay in the power band. Make sure you know what the history of the car has been through.
Old Jun 21, 2007 | 11:02 PM
kingleo1983
yea I got a carfacts on it and everything is clear, What other signs should I look for to tell if this car is good to buy? thanks a lot for the info.
Old Jun 22, 2007 | 02:24 AM
abmtex2007's Avatar
abmtex2007
put it on a lift to make sure it has not had past frame damage. Then check if the hood lines, door, trunk and any other lines are straight. check for oil leaks. check for new clean parts.
Old Jun 22, 2007 | 01:09 PM
kingleo1983
thanks for the info
Old Jun 22, 2007 | 01:45 PM
SVTCobra97's Avatar
SVTCobra97
On top of checking the lines to make sure everything lines up, I would also ask the guy if you and him could take like an hour trip around in it. I have had people I know buy a car and about 2 hours at the most of having it they startedto hear noises, and it started to run ****ty a little while after buying the car.
Old Jun 22, 2007 | 02:02 PM
kingleo1983
Thanks a lot I'll ask to do that
Nov 10, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
Dan04COBRA
Sep 30, 2015 11:46 AM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
Sparks_88
Sep 8, 2015 01:06 PM
