SVT Forums
cams
Old Jun 25, 2007 | 01:10 AM
03supercobra's Avatar
03supercobra
Default cams
have any of you installed aftermarket cams on your terminators and is it worth it
Old Jun 25, 2007 | 01:31 AM
Blownsvt's Avatar
Blownsvt
Default RE: cams
i know some people who have and you can see some gains from head/cam work. but form what i have seen when looking around the cost of just the set of camshafts themselves run around a grand or so, then add in head work, either replacement heads or port work, plus valvesprings and anything else you will need, and shop labor unless you feel comfortable dismantling y9ou engin on your own, and your looking at probaly3-4k i would guess. for that you could get a kb/whipple and install it in one days time and see the same if not more gain.
Old Jun 25, 2007 | 03:14 PM
evil monkey's Avatar
evil monkey
Default RE: cams
A good set of Cam's would make a great investment for your ride. Yes a bit pricey but worth it in the long run
Old Jun 25, 2007 | 08:49 PM
03supercobra
Default RE: cams
i was just asking because i heard the stock ones are good enought and that its not worth spending tha cash for them
Old Jun 26, 2007 | 12:22 AM
Blownsvt's Avatar
Blownsvt
Default RE: cams
aren't good enough for what exactly?
Old Jun 26, 2007 | 01:48 AM
POISND U's Avatar
POISND U
Default RE: cams
ORIGINAL: evil monkey
You don't have a clue, do you?
Old Jun 26, 2007 | 04:50 PM
03supercobra
Default RE: cams
i aint say they arent good enough i said i heard they are just as good as the stock ones. im asking cause not many people switch out their cams on their cobras.
Old Jun 26, 2007 | 08:16 PM
italia18's Avatar
italia18
Default RE: cams
if everything else was done that i wanted to do for my cobra, and i was bored, then id put them in, because you just cant argue that rough idle sound. The **** would sound like a saleen S7 <3
Old Jul 5, 2007 | 10:18 PM
03_svt_cobra_22's Avatar
03_svt_cobra_22
Default RE: cams
the only better heads your gonna get are the ones off of the Ford GT and its a 5.4 so its out of the question... the heads on the stock 03-04 cobras are amost as good as it gets. unless ur looking to push over 800hp then ya a cam swap probly is needed to keep up with all the boost and pressure your gonna be runnin but as for me... na its a waste of money in my opinion
Old Jul 8, 2007 | 01:45 AM
BTRStang's Avatar
BTRStang
Default RE: cams
+1 on they way they sound. But dollar (money you could spendon other parts)to performance ratio not so good! Looking at your mods IMO I would go get a set of long tube headers, heat exchanger, gears, etc... and maybe a bottle and you would still be under the cost of a good set of cams and labor!
