SVT Forums
top speed cobra???
Old Jul 6, 2007 | 02:05 AM
03_svt_cobra_22's Avatar
03_svt_cobra_22
Default top speed cobra???
Alright here it is.... ive got a bone stock 03 cobra and i know they are limited to 155 to 160 mph from the factory and are reved limited to 6500 and fuel shut off is at 7000 rpm [:@]neways i have seen these cars do 160 in 5th at 5700 rpms so the question is... how fast is a bone stock 03-04 svt cobra (with tunining ONLY to turn off the top speed and rpm rev nanny) in 6th gear at 7000rpm?
ive heard the mach 1 does around 165-170 so i assume the cobra will do 180-190mph??
Old Jul 6, 2007 | 02:57 AM
kweb288's Avatar
kweb288
Default RE: top speed cobra???
if your doing that on the street your a ****ing retard
Old Jul 6, 2007 | 12:56 PM
italia18's Avatar
italia18
he never said he was?
Old Jul 6, 2007 | 01:39 PM
spray175's Avatar
spray175
Ive never seen a Cobra go above 178
Old Jul 7, 2007 | 12:56 AM
xxkazp3rxx's Avatar
xxkazp3rxx
The motor can probably handle those speeds, but you won't ever go that fast... not aerodynamic enough. You'd probably wreck.
Old Jul 7, 2007 | 07:04 AM
white07's Avatar
white07
also a little advice..top end runs arent the best thing for your motor. My friend fuc/ded up 3 main bearings and scratched a cylinder wall on his cobra with only 40K miles.
Old Jul 7, 2007 | 02:18 PM
xxkazp3rxx's Avatar
xxkazp3rxx
+1...
High speed runs will pop your motor... Good catch - I forgot about that... lol - the heat gets to the #7 and 8 cylinder...
Old Jul 8, 2007 | 04:24 PM
03_svt_cobra_22
rite i understand that the top end runs do kill a motor for sure... i just heard ppl and did some reasearch that a cobra will run around 180 to 190. course the aerodynamics are no where near as good asa corvette. also what got me thinking is on the mach 1 forums some one said that the mach 1 with the power to pull the 5th gear to the redline could do 170 to 175 so i knew the cobra would stop that in the dirt and therefor posed the question.
ohh and i never would attempt that speed neways... 130 was enought for me lol
Old Jul 8, 2007 | 08:04 PM
Stang9946's Avatar
Stang9946
I'm sure the speedo only goes to 160 for a reason
Nov 10, 2015 11:39 AM
musnicki
Sep 23, 2015 07:11 AM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
Sparks_88
Sep 8, 2015 01:06 PM
