SVT Forums
Bad OEm H-Pipe
Old Aug 17, 2007 | 01:35 PM
lfahey's Avatar
lfahey
Default Bad OEm H-Pipe
Hey Guys,
I need some advice. I own a 97 Cobra, I recently blew the bank 2 catalytic converter on the OEM H pipe. I live in milwaukee , Wi and we have emmissions every 2 years. Can I replace the stock H-pipe and replace with a aftermarket X/H-pipe with cats and still pass emmissions. Most, if not all aftermarket catted X/H pipes only have 2 CATS. If i use MILS what are the possibilities of passing emmissions. Second, would it be best to have a shop do the work to ensure it will pass? Anyone have any experience with this....
I need advice Please..........
lancefahey@yahoo.com
Old Aug 17, 2007 | 02:00 PM
spray175's Avatar
spray175
Default RE: Bad OEm H-Pipe
Why would you use MILS if you have cats. You will pass with an aftermarket mid pipe with cats.
Old Aug 17, 2007 | 02:09 PM
NoRdO's Avatar
NoRdO
If you can do the install yourself, just do it. I have a bbk x-pipe with cats and I live in maryland, we also have emissions every two years. I think all they do is plug a code reader into your computer and make sure all of the emissions equipment is working.
Old Aug 17, 2007 | 04:00 PM
lfahey's Avatar
lfahey
HI,
Yeah the DOT plugs in as well. Problem is i beleive there are 4 O2 sensors.. Not sure, but 1 for each CAT. With an aftermarket I will only have 2 O2 sensors. Wouldn't I have to put MILS on the other 2 O2 sensors? My concern is buyng the new X pipe installing and then failing.... we have a 3 strikes and your out rule...
Any mechanics out there dealt with this....
Old Aug 17, 2007 | 08:23 PM
JamesTronix's Avatar
JamesTronix
You will still have 4 02 sensors, 2 before the cats and 2 after.
Old Aug 18, 2007 | 10:02 AM
lfahey's Avatar
lfahey
So, in looking at many X pipes woth CATS on line I do not seem to see the O2 sensor attachments....Can anyone recommend a good X pipe with cats and with O3 sendsor mounts.....
Thanks !!!!
Old Aug 18, 2007 | 04:03 PM
spray175's Avatar
spray175
http://www.lethalperformance.com/pag...pe-w-cats.html
They all have to have sensors in them. Your stock sensors will just screw out of the old pipe and into the new.
Old Aug 20, 2007 | 08:57 AM
lfahey's Avatar
lfahey
Looks like a decent unit... However does not look like it has High flow CATS. Any others out there that will work?
Thanks Again!!!
Old Aug 20, 2007 | 12:15 PM
spray175's Avatar
spray175
It says premium cats which are high flow.
http://www.lethalperformance.com/pag...flow-cats.html
http://www.lethalperformance.com/pag...with-cats.html
Search my friend there are plenty out there. That took me 2 minutes.
Dathan
Oct 5, 2015 05:52 AM
KingRando
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
winner99
Oct 1, 2015 10:52 AM
Sep 24, 2015 09:18 PM
