SVT Forums
Need some serious advice and opinions
Old Sep 3, 2007 | 07:42 PM
sn95aod's Avatar
sn95aod
Default Need some serious advice and opinions
I am buying a cobra, I have found two one is a 95 that is a hard top convertible/ only 499 made $9,000. and the other is a 1997 convertible $7,600. The 1997 is completely stock with 93,000 miles. the 1995 has this dones to it
afr 165 heads with stock cobra roller rockers
trick flow stage 1 cam
new ford racing timing chain
pioneer sfi balancer
trick flow street heat intake
C&L inlet tube
pro-m 75mm MAF cal'd for 30# injectors
30# injectors
BBK underdrive pullies
Fluidyne radiator
BBK shorty headers for 87-93BBK o/r x-pipeedelbrock catback
performance distributors(pd) computer distributor
pd livewires plug wires
pd ignition coil
pd ignition module
trans/rear end
T56 trans with approx 4k miles on it
fidanza lightweight flywheel
frpp clutch quadrant/cable
king cobra clutch
cust aluminum driveshaft
3.73 gears
frpp 31 spline axles
03 cobra diff
arp diff studs
summit rear end aluminum cover
royal purple fluid changed 300 miles ago
Brakes
braided front hoses
03 cobra calipers in front with good pads
brand new rear calipers/pads/rotors--all oe ford
suspension
maximum motorsports(mm) front coil overs with 10" 300lb springs
mm caster/camber plates
mm bumpsteer kit
mm offset front control arms
mm ride height adjustable rear lower control arms
hp motorsports panhard bar
eibach pro-kit rear springs
tockico illumina 5 way adjustable shocks/struts
steeda full length subframe connectors
frpp strut tower brace
steeda 4 pt bolt in roll bar
steeda ultra lite 1 17x9" wheels with good dunlop direzza 255/40/17 tires
interior
arizen racing seats on stock non-power seat sliders
new black carpet
new oe shift boot
03 cobra shift ****
The thing is that the car fax report says it was in a wreck, a minor collision. I am sure this would be worth some money in stock form because it is so rare but since this guy changed evrything in it even the seats it is probably worth no more than a regular gt right or wrong? And to have all of this stuffdone alrady you don't know the quality of installation. Anyway myquestion is what would you guys do??? all opinions welcome!! Thanks
Old Sep 4, 2007 | 08:41 AM
Mt Twigbert's Avatar
Mt Twigbert
Default RE: Need some serious advice and opinions
Well it depends what your going to do w/ it?
If you get the 97 do you plan on moding it to make more power? Or are you going to keep it stock?
If you think you will end up moding the car then spend the extra $1,400 and get the 95 seeing it has alot done already..
Old Sep 4, 2007 | 01:35 PM
mfj's Avatar
mfj
Banned
i would probably get the 95. Has a lot more modifications that u can use, but how crazy are u going to get with this project. If u just want a nice weekend driver and dont plan on doing a whole lot, then just get the 97. but if major modifications are in ur future, i would go withthe 95 because it comes with a lot already. Of course, im telling u this, without knowing the true condition of either car.
Old Sep 4, 2007 | 01:54 PM
LynnBob Mustang's Avatar
LynnBob Mustang
With the '95 with all the mods, you know it definatly has been beat to $#!+....
Personally I would stay away from some elses headaches and create my own. LOL!!
I turned away several cars because kids got into them with the mods, I wanted something stock so I know what has been done.
Lynn
Old Sep 4, 2007 | 01:57 PM
mfj's Avatar
mfj
Banned
ORIGINAL: LynnBob Mustang
Lynn
well if he plans on going crazy with this car, and forging the bottom end, then it really dont matter that the motor is beat up.
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
Dokilar
15
Oct 16, 2015 08:13 PM
flash_xx
Oct 16, 2015 07:23 AM
mungodrums
Oct 7, 2015 04:01 AM
Sep 3, 2015 07:14 PM
