SVT Forums
Is this over-kill?
Old Sep 11, 2007 | 09:16 PM
Legally_Blown's Avatar
Legally_Blown
Default Is this over-kill?
Is this overkill for a N/A application? I might turbo it when I have the money though. Mods are...
-Original 1999 Aluminum Block Bored .020 Over With a VT Engines 302ci Stroker Kit (Good For 1500hp) 9:2:1 Compression Ratio
-CP Custom 16cc Dished Pistons .020 Over
-CP Custom matched rings
-Oliver Billet I Beam Stroker Rods With ARP 2000 Bolts
-Custom Billet VT Stroker Crank 3.75 Stroke
-VT Billet HO Oil Pump gears
-Tri Metal Bearings
-Arp Head Studs
-1999 Cobra Heads(port & polished, resurfaced, pressure tested, 3 angle seat cut, and valves cut and cleaned)
-Crower 4v 31mm Stainless Valves
-Crower 4v Springs and retainers
-COMP 4v Regrind Cams
-Felpro Perma Torque MLS Head Gaskets
-Metco 8lbs Lower
-Metco 3.7 Alternator Pulley
-New thermostat
-Custom Tuned by SCT racing Tuner (Tuner, Chip, Software and Laptop Included)
INTAKE
-42lbs Injectors
-Ported Throttle Body
-PortedUpper/Lower Cobra Intake
-80mm MAF
-K&N Filter
DRIVETRAIN
-TKO 5 Speed Transmission (1500 miles)
-Lakewood SFI Bellhousing
-Spec Stage4 Clutch
-Spec Aluminum Flywheel
-Custom sized and balanced Aluminum Driveshaft
-UPR Short Throw Shifter
-UPR Double Lock Extreme Firewall Adjuster
-UPR Quick Release Clutch Quadrant
-Ford Racing 4.10's
-Ford Racing Live Axle Swap
EXTERIOR
-2001 Cobra Rear Bumper (Change to have COBRA seen in the back instead of MUSTANG)
-Front Grille Snake Emblem
SUSPENSION
-UPR Tubular Front K-member and A-Arms
-Front Coil over springs
-5-way adjustable struts
-QA1 Caster/Camber Plates
-H&R Sport Springs
-Granatelli Motorsports Upper and Lower Control Arms w/poly bushings
-Drag Launch Springs
-UPR Subframe connectors (Weld-on)
ELECTRONICS
-SCT tuner 4 bank chip
-Kenne Bell Fuel Flow Booster/Controller
-Ignition Controller/Booster
-Autometer Shift Light
-Autometer Air/Fuel Meter
-Autometer Boost Guage
-IBM ThinkPad Laptop (SCT Custom Tuning Software)
EXHAUST
-Bassani Mid Length Headers
-ARP Header Studs
-Bassani Catless H-Pipe
-Flowmaster Catback
-Bassani Catback (Not Installed on car but included in the price)
FUEL SYSTEM
-2003 Cobra Twin Pumps Assembly
-Cobra Baffled Fuel Tank
-42 lbs injectors
Old Sep 11, 2007 | 09:20 PM
mfj's Avatar
mfj
Banned
Default RE: Is this over-kill?
honestly, is there such thing as overkill with us gear heads???
Old Sep 11, 2007 | 09:32 PM
Legally_Blown
very true. you can never have too much horsepower.
Old Sep 11, 2007 | 09:44 PM
zolen's Avatar
zolen
I agree, overkill doesn't exist, but a few questions. For an N/A combo, would you really want dished pistons, they are gonna lower your compression and kill some ponies. Although if you really see forced induction in your future, they would save you the cost of adding dished pistons later. Second, you list a Metco 8lb. lower pulley. I think that is a pulley used to up the boost on the 03-04 Cobras. Given the lack of a blower in your plans, I dont think you will need that one.
Old Sep 11, 2007 | 10:23 PM
Legally_Blown
really? why its on there is a mystery to me then. I just bought this car, but yes, F/I will be in my future when I get the money.
Old Sep 12, 2007 | 08:24 AM
SNAKE_O1's Avatar
SNAKE_O1
As long as you don't go with twin General Electric J-79 aircraft jet engines; you're not overkilling
Old Sep 12, 2007 | 09:20 AM
Martel's Avatar
Martel
ORIGINAL: SNAKE_O1
Thanks for letting everyone know my idea! [sm=tongue.gif]
Old Sep 12, 2007 | 09:48 AM
ponysnake99's Avatar
ponysnake99
The long block sounds likea good foundation for a build up...nothing close to overkill. But correct me if i'm wrong, but i don't think 42 lb injectors are needed for an n/a engine with that low a CR...seems like your pushing a lot of fuel into the car.
Old Sep 12, 2007 | 01:17 PM
Legally_Blown
yes, but if I'm planning on a turbo application when I get the money, why not already have it installed and save money and time?
Old Sep 12, 2007 | 02:04 PM
mfj's Avatar
mfj
Banned
very true, the 42lb injectors won't hurt it. it the computer thats controlling how much fuel is gonna come out of those injectors. 42 lbs an hour is just the max amount those injectors can flow.
