SVT Forums
03 Cobra
Old Sep 24, 2007 | 11:52 AM
ZO6AINTPOOP's Avatar
ZO6AINTPOOP
Default 03 Cobra
Someone I know said that MSD makes a coil packs for an 03 Cobra I do believe that part. But He said that he is going the port his blower and run a 2.93 upper and a 4lb lower and he thinks by just changing the coil packs that is the only mod he has to do to gain! I told him that he is going to either change injectors or buy a boost a pump to keep from leaning out but he said that the coil packs will do it all so is he full of **** or what??
Old Sep 27, 2007 | 07:49 AM
CobraBob's Avatar
CobraBob
Default RE: 03 Cobra
If he is porting his blower, with that upper/lower setup he'll be looking at around 510rwhp. He will definitely need to upgrade his meter and pumps (Ford GT or BAP). Injectors should be okay but it is recommended to go with the 60lb. injectors.
Nov 10, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
Dan04COBRA
Sep 30, 2015 11:46 AM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
Sparks_88
Sep 8, 2015 01:06 PM
