SVT Forums
stock wheel size?
Old Sep 26, 2007 | 04:34 PM
bigmoose15's Avatar
bigmoose15
Default stock wheel size?
hey guys,
does any one know the size of the stock 17" SVT wheels? i currently run 275/40 in the rear and 245/45 in the front, but i want to get fatter in the rear. whats the widest i can run on the rear wheels? will i need a spacer?
thanks
Old Sep 26, 2007 | 07:26 PM
Blownsvt's Avatar
Blownsvt
Default RE: stock wheel size?
i know on the 03 they are 17x9 and you can run a 315 nitto with no spacers.
Old Sep 26, 2007 | 08:57 PM
mfj's Avatar
mfj
Banned
the 01's are skinnier. i really wouldnt go fatter than 275. stock rims are 17x8
Old Sep 26, 2007 | 09:57 PM
Ellik's Avatar
Ellik
I wouldnt even have put 275's on 8" rims!!.
Old Sep 27, 2007 | 11:41 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
ORIGINAL: Ellik
And why not? They fit fine
Old Sep 27, 2007 | 11:49 AM
bigmoose15's Avatar
bigmoose15
i'm gonna physically measure my rim when i get a change to verify its 8". my 275's fit no problem, they don't even buldge at all.
Old Sep 27, 2007 | 12:04 PM
Ellik's Avatar
Ellik
OK, a fat chick might 'fit' into spandex, butthat doesnt mean itsa good idea.Thetires may'fit', but it is TOO much for an 8" rim. when you inflate them, they will hump a little bit in the center, and will handle like crap. You will probably get better traction out of a 255 tire on an 8" rim than you will out of a 275 on the same.
A275 tire wants a 9" rim and 10.5" for a 315.
Old Sep 27, 2007 | 12:50 PM
mfj's Avatar
mfj
Banned
i disagree. my stock 8 in rims fit 275's just fine. yes they stuck out a little, but it did not sacrifice in handling at all, and i got much better traction on the dragstrip with them. and 9 inch rims fit 315 tires too. u dont need 10.5 in rims
Old Sep 27, 2007 | 01:03 PM
TGS2's Avatar
TGS2
ORIGINAL: Blownsvt
I didn't have to use spacers, but I did have to do the IRS bolt kit and I can barely fit a sheet of paper between the tire and IRS bolt. Maybe my offset is different then stock.
Old Sep 29, 2007 | 09:46 PM
riotnet's Avatar
riotnet
hi guys,
I worked for discount tire company for 6 years. I've worked on all types of applications on mustangs from 17 to 20 inch. the 03 and 04 cobras are the only mustangs to have 17x9 inch from the factory with 275/40/17. 99 to 01 came with the same size as all the gt's 17x8 with a 245/45/17. you can run 275/40/17 on the 8 inch rims but the tires will wear in the center faster. the nittos run small, so do the sumitomo's. 315's will fit on the 03 and 04's but the same problem with the 275's on the 8's. I now have an 04 cobra with the factory size but before that I had an 02 gt where I ran 17x9 - 275/40/17 and 17x 10.5 -315/35/17 it set the car off. I was pleased. If anyone has any questions about what fits on what year id be happpy to help you out.
