SVT Forums
Thud/Clunk Noise
Old Nov 12, 2007 | 04:34 PM
xx9gt6xx's Avatar
xx9gt6xx
Default Thud/Clunk Noise
Hey guys the problem just came about around a week ago I want to say. When the car is at a dead stop and I go into reverse, as I let out the clutch there's like a thud/clunk coming from the rear of the car. It sometimes does it too when I downshift. When I'm on the float or just cruising normally it doesn't do it. Any ideas? Like I said it's coming from the rear of the car...
Old Nov 12, 2007 | 07:18 PM
xx9gt6xx's Avatar
xx9gt6xx
Default RE: Thud/Clunk Noise
Anybody?
Old Nov 12, 2007 | 10:38 PM
X04Mach1X's Avatar
X04Mach1X
did you kill the 4.10 already
Old Nov 13, 2007 | 02:18 AM
POISND U's Avatar
POISND U
Differential bushings. Get new ones from MM.
Old Nov 13, 2007 | 11:40 AM
xx9gt6xx's Avatar
xx9gt6xx
ORIGINAL: POISND U
Really? I've had a few guys in the other forums saying U-Joints or the differential needs to be re-shimmed. Did this happen to you?Let me know because that would be a lot easier to fix than re-shimming the differential...
Old Nov 13, 2007 | 07:04 PM
ShaneHayes's Avatar
ShaneHayes
Hey I think I'm going through the same BS. I too was told it might be the u-joins of having the differential re-shimmed. Now I'm hearing the differential bushings? I guess I'll find out when I go to take it to Modular Powerhouse. I'll also keep you all updated. Thanks.
Old Nov 13, 2007 | 07:19 PM
xx9gt6xx's Avatar
xx9gt6xx
ORIGINAL: ShaneHayes
Please do. I'm taking mine to shop class tomarrow and checking theU-Joints and making sure thedifferentialbushings are in good shape and that the mounting bolts are tight. Alsoanother guy on anotherforum saidto check the pinion bearing bolt to makesure that'stight. It could be a number of things, most of which are easy to fix yourself... Unless you need to get the differential re-shimmed...
Old Nov 13, 2007 | 07:20 PM
ShaneHayes's Avatar
ShaneHayes
^Keep me posted too, and I'll do the same. Post up here bro. Thanks!
Old Nov 14, 2007 | 04:21 PM
xx9gt6xx's Avatar
xx9gt6xx
The verdict was the driveshaft bolts being loose. I tightened those bitches up and the noise was gone. Also everything else was tight BTW. Good luck w/ yours ShaneHayes...
Old Nov 14, 2007 | 04:43 PM
ShaneHayes's Avatar
ShaneHayes
PM'd ya. Thanks for the update!
