SVT Forums
01 Cobra HP
Old Dec 7, 2007 | 09:25 PM
njdanmustang's Avatar
njdanmustang
Default 01 Cobra HP
What would it take to make a 01 Cobra push 400rwhp?
Would a Vortech running at about 8psi reach this? Would rather not have to do engine rebuild.
(This is for a friend)
-Dan
Old Dec 7, 2007 | 09:43 PM
Ahnial8u's Avatar
Ahnial8u
Default RE: 01 Cobra HP
8 PSI should easily put you over 420 RWHP I would imagine.
Old Dec 8, 2007 | 12:04 AM
N20Cobra's Avatar
N20Cobra
I have pullies, o/r x, flowmasters, and Anderson Ford Motorsport Powerpipe and an 82mm mass air and I put down 423rwhp and 488 rwtq on a 150 dry shot, motor is completely internally stock. Tuned by Anderson Ford Motorsport using the PMS stand alone.
Old Dec 8, 2007 | 12:38 AM
01snake's Avatar
01snake
yea 8psi intercooled will get you over 400.
also nitrous as stated
OR full bolt on's, h/c/i will put you around 415 n/a
Old Dec 12, 2007 | 09:16 PM
Black*Death's Avatar
Black*Death
I am running 5psi on an ATI procharger on my 99and getting 398 rwhp sooooooo....yes 8psi will put you over 400
Old Dec 12, 2007 | 09:18 PM
03_svt_cobra_22's Avatar
03_svt_cobra_22
8psi and supporting mods will easily
Old Dec 12, 2007 | 11:02 PM
arcticman37's Avatar
arcticman37
boost
Old Dec 13, 2007 | 10:51 AM
hus's Avatar
hus
I'm running a Vortech V2-E with 8lbs on my 01 (42lb injectors, SLP Exhaust, 3.73 gears(gearing doesn't matter of course) and dynoed @ 427rwhp and 464rwtq
Old Dec 14, 2007 | 06:05 AM
bugpack28's Avatar
bugpack28
It should put you over 400 easy and 8psi isn't really pushing it tooo much but look out and get it tuned right my buddies went lean with his tune trying to push more hp out and adding timing and burnt a hole through his piston...
Nov 10, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
Dan04COBRA
Sep 30, 2015 11:46 AM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
Sparks_88
Sep 8, 2015 01:06 PM
