SVT Forums
removing diff cover on 99 Cobra
Old Jan 6, 2008 | 06:05 PM
cdrlmr's Avatar
cdrlmr
Default removing diff cover on 99 Cobra
I was under the rear of my car today trying to figure out how to change the gear oil in the rear end. I happened to grap the driveshaft and rotated it. There is what appears to be play in the ring and pinion. I pulled the fill plug and can not feel any oil that I can reach with my finger. Is there an easy way to remove the diff cover without dropping the entire IRS to check the gears and diff before I drop money for new parts?
Old Jan 6, 2008 | 11:38 PM
97targa's Avatar
97targa
Default RE: removing diff cover on 99 Cobra
That's the way they are for both the backlash and the oil. The old rule is you should fill oil until it's at the bottom of the hole. wrong. That's too much. You'll have leaky seals!!! When you refill just put 1.8 bottles in and your tube of friction modifier. Those rear ends take 3.75 pints. there 2pints per quart minus the friction modifier. As far as getting the cover off??? I'm not an IRS owner. If your that worried, stick a magnetic line in there and see what you come up with. Mass sludge is fine, but shiny particles are not!
Granatelli Sales
Jan 20, 2020 12:34 AM
Nov 10, 2015 11:39 AM
prophotog
Sep 15, 2015 08:38 AM
FivePointToTheOh
Sep 14, 2015 03:35 PM
Sparks_88
Sep 8, 2015 01:06 PM
