SVT Forums
2v to 4v conversion
Old Mar 7, 2008 | 06:41 PM
doug0122's Avatar
doug0122
Default 2v to 4v conversion
i have a 2000 mustang gt right now that has the stock 2v motor in it, i was just wondering besides the engine what ill need to run a NA 4v motor, help is appreciated
Doug
Old Mar 9, 2008 | 07:01 PM
limp1969's Avatar
limp1969
Default RE: 2v to 4v conversion
buy the 4v motor used on craigs list
I just asked this same ? to my engine builder and he said the rest of the bolt on crap you would need to convert is not worth the money you can fine one used much cheaper
Old Mar 9, 2008 | 10:05 PM
Ehmark's Avatar
Ehmark
+1 on buying used. I did it its not too hard. I found it easier than my pi swap.
Old Mar 9, 2008 | 10:47 PM
Ecstasy's Avatar
Ecstasy
buy everything dont just build a motor because you wont find alot of **** to match it up in your car from a 2v.
Old Mar 10, 2008 | 09:15 PM
Ehmark's Avatar
Ehmark
I got bored so heres a short list so you know what we mean by not turning a 2v into a 4v and instead just dropping in whole motor. 2 exta timing chains for the extra 2 cams. 4v heads 4 cams 32 valves+valvesprings and retainers 64 retainer clips. 2 extra timing gears fuel rails intake manifolds Imrc deletes wires timing cover wiring harness ecu flash 24 lb injectors throttle body. total cost depending which parts you use(used stock or fr500 for example.)Somewhere between1200 and 9000+. ouch... A cobra motor ready to drop in will set you back only 3500 on ebay.
HRnB
GT350 S550 Tech
Dec 18, 2015 09:35 AM
Nov 10, 2015 11:39 AM
DCole24
Sep 11, 2015 10:50 AM
YoungStangsMan
Sep 5, 2015 07:01 PM
