SVT Forums
Fluidyne??
Old Apr 23, 2008 | 10:17 AM
Indy03CobraKid's Avatar
Indy03CobraKid
Default Fluidyne??
hey what do u guys think about the fluidyne? is it a worth while purchase i know they say it will run the blower at 25% cooler efficentcy (sp) but does any1 here actually have it installed that could give me some info on them? i appreciate it thanks.
Old Apr 23, 2008 | 10:29 AM
baino's Avatar
baino
Default RE: Fluidyne??
I know this isnt your question but i think americanmuscle sells a cheaper setup that is suppose to produce similar results. Just hard to believe that there could be that much difference between one and the other for the price.
Old Apr 23, 2008 | 10:34 AM
Indy03CobraKid
is th americanmuscle.com? thanks thats actually a good tip. I'm a college student and anywhere i can cut corners and still get the results i want/need is greatly appreciated. trying to get my car to the 500hp level asap without spending to much. Probably do the JLT cold air and an acufab TB n Spacer. Easy bolts on that, unless im wrong should put me damn close to that 500 hp number. lol only 32 hp left b4 i hit that number haha
Old Apr 23, 2008 | 01:08 PM
Blownsvt's Avatar
Blownsvt
i had the fuidyne in my car up until the turbo swap. it seemed to help a little bit with hot lapping at the track mostly. pretty easy to install. i don't know about 25% cooler though.
Old Apr 23, 2008 | 04:19 PM
2k6silvergt's Avatar
2k6silvergt
Are you asking about a fluidyne heat exchanger or fluidyne radiator?
Old Apr 23, 2008 | 05:11 PM
Blownsvt's Avatar
Blownsvt
I assumed he meant heat exchanger since he commented about the blower speciffically running cooler.
Old Apr 24, 2008 | 02:44 AM
Ehmark's Avatar
Ehmark
I got a visteon radiator and it works great. I kept overheating on freeway whenever racingfrom my gears and now whenever I drive on freeway it lowers temp significantly. I would go as far as saying 25%+
Old Apr 24, 2008 | 03:08 AM
AZ SNAKE's Avatar
AZ SNAKE
I have a fluidyne HE and it is easy to install. Not sure on how much it actually cools....
Old Apr 24, 2008 | 02:52 PM
2k6silvergt
ORIGINAL: Blownsvt
Ya that was what I figured also, but there was a similar post on another forum and the person was asking about the radiator. I just wanted to make sure.
Old Apr 24, 2008 | 08:06 PM
mills281e's Avatar
mills281e
My Extreme came with a Fluidyne radiator. My temps run a little bit warmer than my Cobra did. I just assumed that was due to the Cobra's all aluminum block and theWhippleon the Extreme, rather than radiator effectiveness/quality. To be honest, I don't know who makes the H/E's for Saleen though.
LetThePoniesRunFree
May 13, 2007 03:41 PM
91stang
Aug 30, 2006 12:52 AM
SleepingGT
Aug 15, 2006 04:45 PM
SleepingGT
Aug 14, 2006 11:07 AM
velazsc
Nov 27, 2004 06:33 AM
