SVT Forums
Shifter Sticks any Suggestions
Old May 11, 2008 | 11:56 AM
steve04cobra's Avatar
steve04cobra
Default Shifter Sticks any Suggestions
Ok, I installed a pro 5.0 a couple of weeks ago, and i've had no probs since, but last nite i noticed my shifter was sticky, it was hard bringing it out of 1st and putting in second and even second to third...now i left the stop bolts in on the shifter and i talked to a guy last nite and he said i should take them out since the t56 have built in stops in the tranny and that mite be the problem...is this true? or does anyone thinks its something else?
Old May 11, 2008 | 12:34 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Default RE: Shifter Sticks any Suggestions
Well, if it shifted OK for a couple weeks, than the stop bolts are very un-likely to be the issue. Besides, they will not make it hard to shift, just would not let it go completely into gear. How does the clutch feel? Does it seem to dis-engage completely? Froma complete stop, with engine running, put into first gear. does the sound of the engine/rpm's change? Does the car "want" to move forward?
Jazzer
Old May 11, 2008 | 12:44 PM
steve04cobra
The clutch feels fine, there's no movement it doesnt come out of gear or anything
Old May 11, 2008 | 01:06 PM
Jazzer The Cat
Retired Moderator
Sounds like may be a warranty issue with shifter. Take the boot off and see if any bolts are loose or something. If so, DON'T tighten any that you didn't install as it may void warranty.
Jazzer
Old May 13, 2008 | 10:27 AM
steve04cobra
Yesterday I checked it out and there were no loose bolts and the shifter is in place...any other ideas
Old May 13, 2008 | 08:03 PM
baino's Avatar
baino
did you check the stopper bolts just in case?
Old May 14, 2008 | 10:10 AM
steve04cobra
Yeah, I checked the bolts they are not touching at all, when I first installed it the bolts were hitting the handle, but i loosened them, now they are a good turn and a half away from the handle
Old May 14, 2008 | 11:05 AM
Jazzer The Cat
Retired Moderator
Remove the Pro 50 shifter, re-install the original one and see if it works properly. If not, you have some sort of trans issue, unfortunately [&o]
If you don't still have stock one, you can shift by hand, but a little difficult.
Jazzer
firehorse02
Nov 16, 2015 11:28 AM
BeatnikFink
Oct 1, 2015 08:00 PM
guitarman376
Sep 30, 2015 05:54 PM
junior04
Sep 28, 2015 10:53 AM
Suree_Mustang_2009
Sep 25, 2015 12:58 PM
