SVT Forums
cams
Old Jun 19, 2008 | 11:13 AM
99 cobra vert's Avatar
99 cobra vert
Default cams
anybuddy know how much hp I would gain with cams I know there are different cam sizes im just wonder what people have seen for gains i have a 99 cobra
Old Jun 19, 2008 | 09:04 PM
baino's Avatar
baino
Default RE: cams
I asked a similar question on here but got no help. I ended up contacting the folks at lethal performance and asking them. They said that in most 99-01 Cobras, they see between 330rwhp and 370rwhp depending on your supporting mods with a cam swap. Both stage 1 and stage 2 produce about the same hp.
Old Jun 20, 2008 | 02:55 PM
99 cobra vert
Default RE: cams
thankx for the info
Old Jul 12, 2008 | 03:50 PM
quick01's Avatar
quick01
Default RE: cams
http://videos.streetfire.net/video/C...bra_164611.htm
dads comp cam cobra
Old Jul 12, 2008 | 04:48 PM
mfj's Avatar
mfj
Banned
Default RE: cams
you will NEVER get a 70hp boost from cams, on a naturally aspirated 4.6L 4v...
lethal performances adviceis partial, because they want to SELL you the cams...
getting 370 rwhp, even with every single bolt on in the world, is IMPOSSIBLE with a cammed 4.6L
bolt on is defined as any part of your engine, that affects the hp output ofyour engine, but does not touch oil...
Cams will give you about a 20 - 30 hp increase... But when you buy the cam, becareful to consider what else you plan on doing to your car... the best cam for an NA set up is NOT the best cam for a supercharged set up...
as for the terminator guys, unless your running more than 20 lbs boost, with a twin screw, cams are more of a SOUND mod than a performance mod...
end rant...
Old Jul 14, 2008 | 09:01 PM
quick01's Avatar
quick01
Default RE: cams
on my white 04 i got 60 rwhp gain and 50rwtq gain out of stage three comp cams alone. not bad for 14 pounds of boost.
Old Jul 15, 2008 | 02:36 AM
mfj's Avatar
mfj
Banned
Default RE: cams
THATS NOT CONSISTENT WITH THE MANY terminators that i have personally seen cammed, and then tuned...
I would LOVE to see your dyno sheets, because as far as I am concerned, it sounds like a mistake.
And didn't you just make a post about owning an 01 cobra, not an 04? [&:]
Old Jul 17, 2008 | 06:47 PM
bugpack28's Avatar
bugpack28
Default RE: cams
They did a cam swap in one of the older 5.0 mags i remember about putting cams on an o3-04 cobra... couldn't find it on their website but if i remember right they put down over 40 hp at the wheels with the same boost of a ported eaton car... pretty sweet but still a lot of dough to pay somebody if you don't know how to do it yourself...
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
