SVT Forums
Proper Jack Stand placement
Old Jun 20, 2008 | 09:06 PM
Baef's Avatar
Baef
Default Proper Jack Stand placement
Since the search isnt working, and I do not seem to be able to get the proper search string into Google...
Where is the proper (safe) placement for jack stands on a 2001 Cobra? I know where the pinch points are for changing tires, and am familiar with where it is lifted while on a lift. But was curious what the proper placement was for the IRS and how others were holding their cars up.
Old Jun 22, 2008 | 08:22 AM
RuffCat's Avatar
RuffCat
Default RE: Proper Jack Stand placement
I personally don't like the pinch welds at all. They tend to fold over after a while and can fold over when you have your car up on jack stands. I'm definately OCD when it comes to safety when I'm under the car. I jack the car up just enough with a cheesmo jack on the pinch weld up front enough so I cn get me bad azz jack under the front K-member just in front of the oil pan. I place 2 jack stands, one on each of the back bolt area of the control arms. There a flat part there that is part of the main frame of the car. It's solid! As far as the back goes, I jack the car up again enough to get a jack under the pumpkin on the rear end. I put jack stands on a flat area which is just in front of the rear tires. That is what I do for my 97 cobra which is a solid axle. It's the area where the lower control arms are bolted into. I'm not sure if you have that or not.
I would def not use your pinch welds for jack stands. Best bet is to get yourself some 1"x2" steel tubing and have it welded behind your pinch weld for a jacking rail. I have kenny brown's matrix subframe set-up and it works awesome. I use that is I just want to lift one side of the car, ofcourse I can lift 3 tires from one spot with that set-up!
You can jack the car up and the slide rhino ramps under neath the tires, this will bring the car up a bit and you won't have to eeven use jack stands, but only if you can leave your tires on for the work you need to do?
mtgldr
Feb 3, 2024 09:00 PM
Sep 25, 2015 06:42 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
Sep 17, 2015 07:57 PM
yourmom6990
Sep 14, 2015 10:52 PM
