SVT Forums
03 Cobra problem with clutch?
Old May 16, 2005 | 03:38 PM
ekim's Avatar
ekim
Default 03 Cobra problem with clutch?
I took my 03 for a ride yesterday and did a couple of clutch drops in 1st and 2nd. When i did it in 2nd all I got was nasty burning clutch smell and the car didnt move.
As I put it back in 1st it did fine and second was fine also. I dont know if I did any damage or not and if anyone knows please enlighten me.
I have two other mustangs in the 60s and 70s and when I run them up to 3500 or 4000 RPM and dump the cars just roll the tires like there was no tommorow. Is my 03 not made as well or what? I have never had anything like this happen before.
Any help would be greatly appreciated.
Old May 16, 2005 | 04:02 PM
AllVenom's Avatar
AllVenom
Default RE: 03 Cobra problem with clutch?
How many miles? Check out svtperformance for this issue, seems like there are all kinds of clutch issues with 03/04, namely the TOB. There is even a TSB on it. In fact, before the TSB came out I received a brand new transmission ($4100) courtesy of Ford because they didn't have the parts available to fix the problem. Now they change the snout on the tranny which has a better design for the TOB. I believe they'll even change out the clutch if they see wear due to the TOB. I know this doesn't solve your problem, but if your above 15K and you routinely drop the clutch like that, you probably need a new clutch. The stock one does not hold up well, especially if your pullied. Also, I hope you don't have drag radials when doing this or your gonna destroy an axle if you wheel hop.
Old May 16, 2005 | 04:04 PM
ekim's Avatar
ekim
2300 miles, what is TOB?
Old May 16, 2005 | 06:35 PM
birch's Avatar
birch
TOB = throw out bearing
Old May 16, 2005 | 11:21 PM
ekim's Avatar
ekim
Thank you guys, I just spoke to my Ford dealer they said there are 5 or 6 TSB's and will replace the tranny on Monday.
Does anyone know if they would install an upgraded clutch pack? If so any recommendations?[sm=feedback.gif]
Old May 17, 2005 | 12:18 PM
AllVenom's Avatar
AllVenom
ORIGINAL: ekim
That's great news. I would say no, especially while your under warranty.
Old May 19, 2005 | 10:15 PM
VernLaw's Avatar
VernLaw
ORIGINAL: ekim
Did they agree to replace the whole transmission or just the clutch and TOB?
Old May 31, 2005 | 02:35 AM
axe20's Avatar
axe20
ORIGINAL: AllVenom
What do you mean of TSB?
I have the same problem and iam going to replace it with spec clutch stage 3 ,what do think?
Old Jun 2, 2005 | 10:01 PM
99saleen351r's Avatar
99saleen351r
ORIGINAL: axe20
ORIGINAL: AllVenom
Spec three clutches have a ton of pedal pressure it sucks for traffic
Old Jun 4, 2005 | 02:21 AM
AllVenom's Avatar
AllVenom
ORIGINAL: axe20
ORIGINAL: AllVenom
That's entirely up to you, but I'd get the TOB problem fixed first for free and you'll probably get a new clutch out of it as well (of course it would be stock though). There is a TSB that addresses the problem with the tranny and the TOB, so if you hear a squeak until you lightly apply pressure on your clutch pedal, then I'd take it in to the dealer. Also, do a search on clutches over at svtperformance.com, there are plenty of guys running non-stock clutches and maybe there is a better alternative to spec.
