SVT Forums
HID Problems
Old Sep 21, 2008 | 03:01 PM
pitmitch910's Avatar
pitmitch910
Default HID Problems
so i bought the dual beam BI-Xexon kit from VVME HID, and they look great but dont fuction correctly, when the low beams are on (switch in middle post.) the high beams are on, then when i push the switch to the High beam post(all the way forward) the only thing that happens is the fog lights go off like they should, but the wierd thing is, is when i pull the switch back to flash my high beams the low beams come on. then also if i have the lights completely off during the daytime and i pull back to flash my high beams then the high beams actually work, i cant figure it out all the wiring is correct, is there something i need to switch like a relay or fuse?
Old Sep 21, 2008 | 07:33 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
I have a couple links that may be of some help to you. Not sure if these will directly answer your questions, but may be of some assistance:
My Projector & HID install
Foglight install
There are a couple nice little tricks to get the fogs to work full-time reguardless of high-beams or not.
HTH (stole that from F1fan )
Jazzer
Seanam
Oct 4, 2015 10:15 AM
kawiguy827
Sep 22, 2015 10:52 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
Mobiusone stang
Sep 7, 2015 08:46 PM
