SVT Forums
96 cobra starting problems
Old Oct 19, 2008 | 10:31 PM
bigdogsracing's Avatar
bigdogsracing
Default 96 cobra starting problems
Ibought this car about six months ago and it has bbk long tube headers o/r hpipe msd coil packs,accell wires,373 gears,pro 50 shifter,and some other small bolt ons.Anyway about two months ago it stared having a small miss or stall when you took off.Then it got to where when it sat overnight it starts fine but if you drive it and shut it off and try to start it back up you have to hold it to the floor.The stalling got worse if you let off while driving in town and gas it again it would miss for a second.now I have been told a number of things to do. So I put a new upr adjustable fuel pressure regulator,gauge,fuel injectors,engine coolant sensor and done IMRC deletes pretty well at the same.Now it seems my miss or stalling is gone while driving but still does it taking off sometimes.Also you still have to hold it to the floor to get it to start. So if anyone has any more suggestions on what to try next I would greatly appreciate it Thanks.Sorr for the big spill but I dont know what else to try!!
Old Oct 21, 2008 | 08:25 PM
bigdogsracing
Never mind fixed it last night!!!!!!!!!!!!!!!!
Old Oct 21, 2008 | 09:36 PM
mfj's Avatar
mfj
Banned
Glad you got it worked out...
Old Oct 21, 2008 | 10:07 PM
SVTeeshirt's Avatar
SVTeeshirt
mind me asking what the problem was? i had similar issues i solved recently.
Old Oct 22, 2008 | 02:44 AM
Hlistr_07RR's Avatar
Hlistr_07RR
I always jizz first
+1 let us know what it was so we can have a heads up for the future. Knowledge = power
Oh and hit the enter button every once in awhile when you post.
Old Oct 22, 2008 | 11:40 PM
bigdogsracing
Oh sorry guys I was in a hurry.Anyways a freind of mine said it sounded like the coolant temp sensor was bad or had a bad connection so I bought a new sensor ended up trying three.No change so I took a tester and checked the plug and no volts. should have 5 volt to the plug.Then I traced the wires to the pcm and tested for breaks in the wires and sure enough no power through the signal wire fixed it and fired right up and has not missed or failed to start since.I feel pretty stupid I changed alot of stuff for nothing oh well live and learn right. Hope this can help someone else Thanks Derick
Old Oct 23, 2008 | 12:43 AM
SVTeeshirt's Avatar
SVTeeshirt
yeah coolant temp sensor and wires to it on mine caused it not to start recently.
Diode Dynamics
28
May 26, 2022 12:02 PM
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
jjwinel78
Aug 17, 2015 03:34 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
Pain.
Aug 7, 2015 10:48 PM
