D1SC procharger on 01 Cobra
Whats going on guys? I got a couple of questions before i go and purchase the D1SC procharger kit. i know im going to need upgrade the fuel injectors, fuel pump, and mass air meter. But other then that what else should i upgrade. Already have lower compression and all forged internals and a BUILT T-45. And after i do install this kit what kinda horsepower will i be looking at? What size injectors? what size and kind mass air meter? what kind of fuel pump?
Horsepower will be based on the size of the pulley you use, with forged internals you will be able to run a good amount of boost, but your tuner will be able to help you with the pulley size you need. These are my guesses it really depends on how much boost you run to figure out how much fuel you will need. If you want you can e-mail Mike Bell with the link below he could answer anything you need to know about Procharger.
Injectors: 60lb
Fuel Pump: Twin Corba Hi Volume Pumps
Mass Air:PMAS
Injectors: 60lb
Mass Air:PMAS
Nov 10, 2015 11:39 AM
Dan04COBRA
Sep 30, 2015 11:46 AM
