Tire buying time!
Ok I have a 03 Cobra with the mods listed below. About 500hp to the wheels. Now am I better off with the new 315/35/17 Nitto NT05's, 315/35/17 Nitto 555R's, or 255/50/17 Nitto Invos? (Please dont list any other type of tire, im set on one of those three after research). I use the car everyday wet,dry, cold and hot weather. Summer is coming up so it would be more for hot weather and also I need inspection in 4 months so I need the tire to keep good tread until then so I pass. Right now I'm liking the NT05's cause all I'm hearing is good things bout them. Any advice?
i second his question and nt 01's are great for dry warm weather...its a very soft tread with not to many groves to expell water...the 555's are also a soft rubber but do really good in rain...lastly cold weather and snow with any of those nittos will be imposible...i live in ohio and i am living proof to cold weather and not even an 1/8th of an in and i was going sideways down the road tryin to take it to my other garage.
+1
The Nitto Drags will be the anything that'll work out of what you mentioned with your power. They can last anywhere from 10-14 months depending on you.
I had my Nitto Drags that were done after 10-11 months... My Cobra saw about a dozen track runs per set. Good luck.
Nitto 555R Drag radial ... i cant see the NT01 having better traction then the radial.. i hadn't heard great things about them either.. i know from experiance that i can cut 1.6-1.7 60" with 500rwhp on a 555r d/r
