SVT Forums
Whipple crew get in here!!!
Old Mar 31, 2009 | 05:11 PM
Tim99GT's Avatar
Tim99GT
Default Whipple crew get in here!!!
Ok, so i am not going to retype my whole original thread(will take forever).
Please read through this so you will have a understanding of what i am going to talk about.
https://mustangforums.com/forum/4-6l...ssibility.html
Thanks!
Anyway, what i need to know is what are the guys with the 3.4l whipple running it at psi wise? are you running race gas? when is the blower the most effiecient? i heard that it doesnt really start making good power unless you are spinning the **** out of it?
any info on this blower would be greatly app as you guys are pretty much the only ppl who run the 3.4l whipple
Thanks!
Old Mar 31, 2009 | 05:20 PM
Mustang3GT07's Avatar
Mustang3GT07
I believe there is only 1 cobra on this site with a whipple. You will have much more luck over on SVTP.
Old Mar 31, 2009 | 05:41 PM
mfj's Avatar
mfj
Banned
I have the 3.4L whipple...
I am running the stock pulley on it (3.5) with the stock lower, and I am making a tad over 23 lbs of boost...
On a conservative tune (12 degrees of timing and 10.6 afr) I am able to run pump gas, with ZERO knock (ping)... The blower is INCREDIBLE efficient. At 70 degrees ambient, IAT'S were mid 90's. I am running a built engine, 5.1L stroker, ported heads, and cams. On a stock engine, boost with the same pulley would probably around 25 psi...
A lot of the Cobra guys running the 3.4 whipple on stock cobra engines, are putting SMALLER lowers, to reduce the boost. Some all the way down to 18 psi. At 18 psi, the 3.4 really doesn't make any more power than the 2.3 does. The blower likes to spin fast, and that is where it really excels...
As for bolting on the the 3.4L Whipple, it is just like any other twin screw. Only extra thing is that my hood needed to be notched very slightly to fit it. Also, it REQUIRES after market fuel rails... Everything else is direct bolt on...
Old Mar 31, 2009 | 06:17 PM
Tim99GT's Avatar
Tim99GT
hmmm i thought the range of the blower was from 12-30 psi? kinda lost when you say stock upper and lower pulley making 25 psi on stock 4.6.shouldnt the stock pulley equal 12 or so psi?
this (if i decide to do it) will be going on a built engine although not bored out. still a 4.6l. so at 18psi, the blower is just entering the lower efficiency range. What kind of numbers are they laying down? why not go to 19 or 20 psi? why do they install the smaller lower to lower the boost?
keep in mind this is a 2v.... dont know if you read the previous thread or not.
Old Mar 31, 2009 | 07:11 PM
945LSTANG's Avatar
945LSTANG
+1
a lot more whipples over there.
Old Mar 31, 2009 | 08:41 PM
mfj's Avatar
mfj
Banned
The 3.4L Whipple is huge... If you understand how positive displacement blowers work, you should understand why the lowest boost numbers from the Monster Whipple are so high... 12 psi from a 3.4L Whipple? HAHAHA! Maybe if you try running a custom 5 inch pulley, lmao! But at that range, it is spinning way too slow...
25 psi is too much for pump gas, hence the reason the stock 4.6 cobra guys are getting smaller lowers, to run lower boost.
Old Mar 31, 2009 | 09:04 PM
jumperjack's Avatar
jumperjack
There are a bunch of guys over on ModFords running the 3.4. There are a bunch of threads on them there.
Old Mar 31, 2009 | 09:14 PM
Tim99GT's Avatar
Tim99GT
i was going by lethal performance's web site for the boost range:
http://www.lethalperformance.com/sup...-black-p-12952
what is the max psi the 4v guys are running before having to go to race gas? and you never did say what they are laying down(hp/tq) at 18 or so psi.
Old Mar 31, 2009 | 10:26 PM
MAD SVT's Avatar
MAD SVT
+1.... haha just run without a hood and it'll fit.
that thing is effen H..U..G..E
Old Apr 1, 2009 | 10:09 AM
Yellow Fever's Avatar
Yellow Fever
Unless you're running over 22psi . Then don't install the 3.4 These things work best over that number . The 2.3's are great up to 22psi . Then run out of efficiency after that . That's what I have been told .And that's why I chose the 2.3 . I don't want to run race gas and won't be winding the **** out of my system anyway . If you want the WOW factor . The 3.4 will do it for you . Either one will require you to replace your factory GT hood . As I did with the 2.3 . You can lower the engine . But with headers and deep oil pans I wouldn't recommend that route .
