SVT Forums
weld wheels
Old Apr 8, 2009 | 06:25 PM
coldblooded01's Avatar
coldblooded01
Default weld wheels
i have an 2001 cobra and i was wondering if i would be able to slide some weld centerline or like wheel under the car with out haveing problems with the rather large brakes up front and back
Old Apr 8, 2009 | 06:44 PM
coldblooded01
15X4 WITH A 2.25" BACKSPACING
Old Apr 8, 2009 | 09:40 PM
MAD SVT's Avatar
MAD SVT
you'll need spacers, with the 2.25 backspacing, i'd guess that the spacer would need to be 3/4" to clear the brakes
Old Apr 9, 2009 | 08:33 AM
Timspony's Avatar
Timspony
SVT Section Moderator
this is something I've been looking into myself...I think Weld also makes a 17" wheel...I need to get rid of that front end weight for the track!
Old Apr 9, 2009 | 10:48 AM
Blownsvt's Avatar
Blownsvt
i run welds. you need a spacer. I am running a pretty large one up front to clear the brakes. the rears barely clear on my car but they clear. i am running 15x3 up front with a 1.5" back space.
Old Apr 9, 2009 | 10:50 AM
Blownsvt's Avatar
Blownsvt
They do make a 17" alumistar front runner. When i got my welds there was a wait on them and they wanted around 400 per wheel i think it was. The 15" prostars were 135 each so for how little i use them i went that route.
Old Apr 9, 2009 | 11:18 AM
Timspony's Avatar
Timspony
With the wheel spaces, did you have to get longer studs or anything??
Old Apr 9, 2009 | 09:07 PM
MAD SVT's Avatar
MAD SVT
yes, the studs should be the standard length + your spacer thickness.
Old Apr 9, 2009 | 11:20 PM
Blownsvt's Avatar
Blownsvt
i have a hubcentric spacer with integrated studs. it bolts to the regular studs then has a seperate set that go through the wheel. I did change those out for 3" studs in the space to make it easier to get the shanked lug nuts on for the welds.
Old Apr 10, 2009 | 06:17 AM
Timspony's Avatar
Timspony
Thanks! ^^^^
