SVT Forums
Evans NPG+
Old May 28, 2009 | 03:56 PM
Martel's Avatar
Martel
Default Evans NPG+
Is it worthwhile to switch over to NPG+ or is this a waste of money on a more or less stock engine? Is anybody using this product?
Old May 29, 2009 | 01:47 AM
Smokin04's Avatar
Smokin04
Well it's hard to justify on a stock motor because while the coolant itself can be had for under 150 bucks (enough for a whole cooling system), Evans "recommends" you buy the water pump/radiator/thermostat housing/etc...to make the whole system more efficient. I recently thought about doing this because when you realize how a cooling system works, the Evans stuff is truly amazing and DOES reduce detonation possibilites due to overheating. With no water also means little to no pressure, so the coolant is far superior to water based coolant. The cost didn't justify the switch for me anyway...at least not right now.
Old May 29, 2009 | 02:39 AM
Martel's Avatar
Martel
I talked to the guys at Evans on the phone. You don't need to trade any parts on our vehicles, just do a chemical flush removing the frost plugs (it has to be a 'complete' drain and flush) then add the NPG+ as with any other fluid. Main thing is to have less than 3% water on an aluminum engine. I believe an iron block need less than 5%.
Old May 29, 2009 | 03:36 AM
Smokin04's Avatar
Smokin04
Yeah they told me that too...right before they said we HIGHLY recommend buying the other stuff. Of course it's not necessary. Just do research before you spend any cash.
Sep 16, 2015 07:53 PM
4digchevy
Jun 12, 2008 10:49 PM
mustang86driver
Aug 7, 2007 05:11 PM
